Whirlpool 1100 watt microwave
This Whirlpool countertop microwave provides numerous features required for various types of cooking, no matter what who is cooking the food. Its capacity is best in class, as offers 2.2 cu. ft, which is the biggest among other Whirlpool countertop microwave.
It’s the best feature is sensor cooking, which adjusts the cooking time automatically, so you don’t have to guess. From snacks to dinner preparation, Whirlpool WMC50522HZ is there to help you out in any situation.
    nooshinjohn Posts: 26,063
    Yes, but can it grill the perfect filet mignon?
    F1nut Posts: 52,151
    I was going to buy one tomorrow, but thanks to your spam post I decided against it.
  • Willow
    Willow Posts: 11,308
    what? I don't have to guess anymore? what fun is that?
    Viking64 Posts: 7,701
    edited September 2019
    Does it have a removable power cord? Does the glass turntable come stock with 3 layers of Dynamat? What are the capacitor values if I want to upgrade? Can it be bi-wired? How is the synergy with a Stouffer's large size lasagna? Are there adequate cooling fins? Is there a universal remote? Does the window in the door support 4K Ultra HD? Will the factory spikes scratch my kitchen countertop?
  • mlistens03
    mlistens03 Posts: 2,767
    Viking64 wrote: »
    Does it have a removable power cord? Yes.
    Does the glass turntable come stock with 3 layers of Dynamat? No... It has 4.
    What are the capacitor values if I want to upgrade? 15,000,000μF.
    Can it be bi-wired? Not yet, unfortunately, although we may see this added to the next generation!
    How is the synergy with a Stouffer's large size lasagna? Very, very good. I use this with Stouffer's myself, and it sounds works like a dream.
    Are there adequate cooling fins? The heatsinks can dissipate a quintillion watts, so while it cooks it runs very cool!
    Is there a universal remote? Yes, this is compatible with the Logitech Harmony remotes.
    Does the window in the door support 4K Ultra HD? This is an option, it is an additional $350.
    Will the factory spikes scratch my kitchen countertop? No, they are specially designed to prevent that. We call them Butylene Spikes. We thought about making that an acronym but changed our minds for... erm, reasons.
    :p
    mlistens03 wrote: »
    :p
    Would you describe this as a "polite" microwave? :p
  • sucks2beme
    sucks2beme Posts: 5,694
    Is there a option with tubes??
  • Willow
    How would you describe the sound? Will there be a stand-up version of this? my gigawatt toaster takes up lots of room.
  • erniejade
    erniejade Posts: 6,321
    Isn't a Whirlpool like a hot tub? Adding microwave to the water might not be a good idea.
  • Willow
    erniejade wrote: »
    how do you expect to heat it...duhh ;)
  • erniejade
    Willow wrote: »
    erniejade wrote: »
    I stand corrected!!
  • mlistens03
    Viking64 wrote: »
    mlistens03 wrote: »
    :p
    Not really. It won't fatigue your food but it is more designed for a lively and musical soundtaste.
    sucks2beme wrote: »
    Not with this model, but you can move up to the WMC50522HZ-3 which does use tubes. (This model is the WMC50522HZ-1.)
    Willow wrote: »
    It sounds very, very nice. there is a lot less noise than a traditional microwave, because of our Class A bias. The entire design is to make that wonderful 60hz hum come out cleaner.
    erniejade wrote: »
    This is a question we get asked quite a bit. We used to make terrible washing machines but eventually, people realized they were awful. Now we make terrible microwaves.
    :p
    (Note: I don't actually know much about this brand, but I do know that we have Whirlpool appliances. this is only a part of the joke :) )
  • decal
    decal Posts: 3,205
    Keep on feeding the trolls/spammers and they will nver leave.
