Receiver/Turntable/Speaker Options
JKParadis
in Electronics
I've picked up a number of components, all from different eras. Some I bought at thrift stores, inherited, or purchased from private sellers. One day I plan to plug and play various combos, but I thought I would begin with advice from you experts. Thanks in advance. Here it goes:
Receiver - Pioneer QX 945 vs. Harmon Kardon 680i. The HK is perfect. The Pioneer cuts out periodically on one of the channels. I had it cleaned/repaired last year already.
Turntable - Newer Audio Technica AT-PL120 vs. vintage PL 71. Both work fine
Advice on speakers, I'd like to have a 4 speaker set up. All work great:
DLK 1 1/2
Teledyne Olson SS-930 (I like them because they are smaller and fit my living room better, along with the larger sets you see here).
Sansui 7070
Jensen Model 4
Again, any help on a solid combo is appreciated.
DLK 1 1/2
Sansui 7070
Jensen Model 4
You should try everything and stick with what you like best!
IS the Pioneer a QX949? The QX949 was a top-tier quadraphonic (4 channel) receiver of the early/mid 70s. 'cutting out' may be as simple as dirty controls -- go to www.audiokarma.org and search for "idiot's guide to DeOxit" if you feel reasonably handy. If it's a QX949, it is certainly the most 'collectible' of the three receivers you mention.
Scan_Pic0048 by Mark Hardy, on Flickr
Is the hk an hk680i or 690i? Either way, a later, but a good receiver.
I am less familiar with the former, but I have one of the latter
The Sansui 7070 is a midline receiver from a good line of Sansui components. Also a pretty good receiver.
sansui782 by Mark Hardy, on Flickr
The PL71 was a good tt and would (should) be far preferable to the A-T (depending on its condition, of course). Do you know what cartridge is installed in the PL71?
The speakers are, in all three cases (DLK, Olson, and Jensen) unremarkable (at best) and - IMO - will absolutely and irrevocably be the weak link for you.
Info on that DLK line at:
http://www.alliedcatalogs.com/html/catalogs_additional/1975-schaak/
It might be the best of the three you mention -- but that's going to be pretty much up to your ears & tastes in reproduced sound.
There's a 1974 Olson catalog at:
https://www.americanradiohistory.com/Archive-Catalogs/Consumer/Olson Radio-1974-Catalog.pdf
Perhaps your Olson speaker's in there(?)
Jensen made some fine drivers and loudspeakers, mostly in the 1950s. The Jensen Four... ain't one of them.
The Jensen 4, amusingly, can be found in the above-mentioned Olson catalog.
HTH, as they say.
Sorry, it is the 949. I may try another shot at cleaning it and running the HK 680i for a spell.
Oh, and thanks fr the help and the catalogs.
de nada.
You also might want to ask (or at least do some searches) at www.audiokarma.org
They're more into the vintage 70s hifi kinda thing over there than most folks here.
Absolutely. Mix and match and have fun.mhardy6647 wrote: »You should try everything and stick with what you like best!
And don't forget that cartridges can be swapped (i.e., if the cartridge on the AT is 'better', it can be mounted on the PL-71). Let us know what you're working withmhardy6647 wrote:The PL71 was a good tt and would (should) be far preferable to the A-T (depending on its condition, of course). Do you know what cartridge is installed in the PL71?
Reminds me...I saw some old Jensens in my dad's garagemhardy6647 wrote:The speakers are, in all three cases (DLK, Olson, and Jensen) unremarkable (at best) and - IMO - will absolutely and irrevocably be the weak link for you.
I know the OP is asking about Jensen Model 4, but I noticed that the Model 5 reminds me of something...
They won't if you listen to them....
That "twin midrange" design was a thing for a while; started (at least in earnest, and AFAIK) by Henry Kloss' KLH Five.
DSC_7011 (2) by Mark Hardy, on Flickr
(nice pair of - borrowed - KLH Fives, being driven - for lack of a better word - by an ACA
in this instance)
hmm...
KLH Five
KLH5 by Mark Hardy, on Flickr
Jensen 5
Radio Shack Optimus 5
source: www.radioshackcatalogs.com (1976)
Coincidence?
I think not.
