Moving house - 1.2 TL SDA Speaker transportation
Hi all,
Needing a bit of advice, I am moving house and am looking at options for shipping my Polk Audio 1.2 TL speakers. When I purchased these I hired a van and moved them myself, but seeing as this time it is interstate I don't have that option.
Just wondering if fellow members might be able to provide some tips/advice in regards to packaging and protecting these speakers for shipping.
Any and all advice greatly appreciated :)
    txcoastal1 Posts: 13,519
    Loctite Power Grab the magnets, Lay on back and ship via freight on pallet
    Modify large wardrobe boxes and use insulation board ti fill in the gaps
    pitdogg2 Posts: 27,578
    Also short the binding post. Sticking short piece of wire between red and black binding post and tighten down. It will help keep the drivers from flopping up and down.
    Fwiw i just used the ground wire from romax house wire.
  • daddyjt
    daddyjt Posts: 3,192
    What states are you moving from/to?
    I personally would do everything I could to move them myself, and not ship them.
    ― Aleksandr Solzhenitsyn
  • Emlyn
    Emlyn Posts: 4,872
    There are always risks in moving. If hiring a moving company, discuss options with them during the initial price assessment. The speakers are really like big pieces of furniture so they should be able to wrap them and put them in the moving truck standing up and braced so they don't move around. They should not be picked up and hand carried. A furniture dolly makes it very easy to move them. If desired, the drivers can be easily removed and boxed separately. I've moved several sets of these speakers myself without damage and taken no extra precautions.
  • motorstereo
    motorstereo Posts: 2,395
    daddyjt wrote: »
    This^^^. Mine were several states away when I brought them home unscathed in the back of my suv laying on their backs. The big sda's are but one of many things I would not trust a moving company with.
  • Schurkey
    Schurkey Posts: 2,122
    edited July 2019
    Thanks. You saved me some typing.
    Although...when it was me, and I was shipping SRS2 pin/blades via U-Haul, I removed the midwoofers, bolted them together face-to-face in pairs using hardware store machine screws, used cheap-junk zip-cord to short the speaker terminals, then packed the midwoofers in bubble-wrap, in cardboard boxes separate from the speaker cabinets.
  • Nesmith98
    Nesmith98 Posts: 225
    Just tell the shippers it's the in-laws and to be very careful.
    nooshinjohn Posts: 26,066
    Nesmith98 wrote: »
    Give Jesse back his bedroom set.
    F1nut Posts: 52,166
    That's not mine, I've got disco lights.
    F1nut Posts: 52,166
    c0redumpt wrote: »
    Hi all,
    Flat on their backs is the only way to transport them.
  • ken brydson
    ken brydson Posts: 9,061
    c0redumpt wrote: »
    Hi all,
    Sounds like my wife... Wait, what?
  • gmcman
    gmcman Posts: 1,864
    I don't know of this is recommended or not, but If I were sending my SDA's, I would remove the PR's and take them with me.
    Especially ones with the 15" PR's.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    If I were shipping my 1.2TLs, I would:
    1. Completely disassemble them, including removing end caps, and label all parts.
    2. Individually box all drivers, passive radiators, tweeters, crossovers, and internal wiring and put them in one bigger box. Label the ends of all internal wiring connectors.
    3. Individually wrap each end cap and place the caps for a single speaker in the same box.
    4. Place some type of thin wood board or double wall corrugated board over the grilles to protect them. Carefully wrap and securely band each speaker cabinet similar to procedures for wrapping and banding fine furniture.
    5. Ship the cabinets lying on their backs.
    If the trelocks (the little black nibs that hold the grilles and side panels) were easily removable, I would also pack the grilles and side panels separately. However, shipping the cabinets without the side panels and grilles on would expose the trelocks to damage.
  • verb
    verb Posts: 10,176
    Agree with DarqueKnight. That's the only way to ensure they arrive safely. If I may add, um, step #6:
    Ship all boxes to Verb's house! :smile:
  • RobbyKY
    RobbyKY Posts: 117
    I moved all my SDA's from Kentucky to Texas in 2017. Four trips and did "basically" what DarqueKnight recommended.
    Removed and packaged all the drivers separately. Inserted foam behind the passive to keep it from bouncing too bad and left the tweeters in place. Grills stayed on, covered cabinets with bed sheets and placed 3 sections of pink foam between them and next to the doors. Erie feeling looking back there when the 1.2's were in place.
    Our corporate relocation company refused to handle "collectables" or my golf cart so I was stuck moving my model trains and massive bourbon collection as well. The 1.2's fit perfectly in the back of my Sequoia and then I had a U-haul or flatbed in tow for all four trips. 925 miles, 17 hours one-way. Would leave at 6:00am Saturday, drop off, sleep and drive back on Sunday. Exhausting! One trip, the U-Haul had a blowout in Benton, Arkansas and scared the crap out of me. To their credit, U-Haul located me on GPS and had it changed out with me back on the road in 75 minutes.
    Media Room: Parasound JC-5, Cambridge 851N, Schiit Freya, SDA SRS 1.2tl
    Game Room: Carver M4.0t, Carver C-4000, Oppo BDP-105, SDA SRS 1.2tl
    Bar/Card Room: Carver TFM-55, Carver C-1(BillD), Oppo BDP-93, SDA SRS 3.1
    Son's Room: Carver TFM-55, Carver C-1(BillD), Laptop/AQ Dragonfly, SDA SRS 3.1
    Bedroom: McIntosh MC150, Cambridge CXN, SDA 2Btl
    Outdoor Pool Area: Yamaha R-N803 with four Polk Atrium 6
    HT: Polk RTi A9s, CSi-A6, RT-65, RTi-A3's, Marantz SR5012, XPA3, UDP-203, Epson 5040UB
