Thoughts on this TV?
Saw this set at Costco a couple weeks ago. Haven't bought a TV in years so I don't know what to look for. A bit leery about being a floor model but since Costco doubles the warranty that's probably a non issue. Oh, and I went by today and it was further marked down to $890....
  • Mikey081057
    Mikey081057 Posts: 7,127
    Garage | Polk Monitor 5B's
  • rooftop59
    rooftop59 Posts: 8,120
    That Tv is a Costco specific model and I’m not sure of the standard equivalent. Although it seems mid level, $890 for a solid 75 4K tv with Costco warranty is pretty insane imo...
    Game Room 5.1.4:
    Bedroom 2.1
  • Mikey081057
    Hey it's got the warranty and you could always return it right?
  • cfrizz
    cfrizz Posts: 13,415
    It's a Sony, enough said. GET IT!
  • rooftop59
    DSkip wrote: »
    Where do you live ken?
    He lives in Washington state. Long ways from Houston!
    Game Room 5.1.4:
    Bedroom 2.1
    Tony M Posts: 11,855
  • Emlyn
    Emlyn Posts: 4,866
    It may be possible to check the number of hours the TV has been on through a service menu if the remote is available to you. Of course, they might not want you to do this unless you buy it.
    Hard to beat a 75" screen for under $900 from any place.
  • BlueFox
    BlueFox Posts: 15,250
    Love my Sony 75” Z9D. Buy it.
  • mrloren
    mrloren Posts: 2,474
    that's the Sony equal to the Samsung 7 series. At that price go for it. If it last a year it will last 5 years. If you're going from 1080p to 4k it will look amazing
  • adb3da
    adb3da Posts: 507
    A little over a year ago I bought a floor model Sony 65” X900E from Best Buy and I absolutely love it. The picture quality blows away all the other TVs we’ve had and those other ones aren’t that old. I say do it!
  • WagnerRC
    WagnerRC Posts: 2,219
    edited June 2019
    I considered buying the Costco Sony, but went to Best Buy and pay a little more to get the one we saw had the better ratings. A few more bucks upfront is worth it.
    On edit we still use our Panasonic 50 inch plasma that we purchased from Costco in 2006 and it works great.
  • rpf65
    rpf65 Posts: 2,127
    The KD models are the lower end sets from Sony. The picture quality isn’t as good as the X series, couldn’t find screen type on the 780, but the 750 and 850 series use ipa screens. These generally tend to be more grayish, when viewed from directly in front of screen, but are better at wider angles than VA screens.
    Here’s a list of some specs:
    https://www.geekylist.com/sony-kd-75x780f-television-1174
