My soundbar turns on by itself, after being turned off. How do I stop this?
Just bought a sound bar on Wed. Set it up earlier today, and it sounds great. However, it began turning on by itself after being shut off. How do I stop this?
Answers
    Get a different soundbar ? :)
    Does it turn on by itself with the TV off ?
    Go into your TV's audio settings and see if there are options. Like an auto detect mode, every TV is a little different on how they handle the audio output. The soundbar is detecting a signal and turning on, when the TV is on.
    Though I would think most get a soundbar to be left on all the time anyway due to the poor speakers in todays TV's.
  • DaveHo
    DaveHo Posts: 3,583
    We've covered this before. It receives a signal, it turns on. That's what it's supposed to do. Why would you want to use the crap speakers in the TV? That's why you bought the soundbar, right?
  • I bought the soundbar to get better audio while watching movies (blu-ray & dvd). For watching tv, the soundbar doesn't need to be on all the time
    jackpbrown wrote: »
    If you don't want it on while watching TV, don't connect it to the TV. Connect it to a receiver. That way you have more control over when it's on.
  • DaveHo
    DaveHo Posts: 3,583
    edited June 2019
    jackpbrown wrote: »
    Well, as someone who fires up the entire home theater to watch TV, this makes no sense to me. Good sound is good sound, no mater the source. Are you trying to pinch pennies or just annoyed you have to turn off the sound bar when you're done? There's a solution for that, it's called a universal remote. Harmony is a good brand. Everybody with more than one remote should own one.
