Polk Monitor Series CS2 center
CoilOdysea
CoilOdysea Posts: 1
edited June 2019 in Troubleshooting
I just recently purchased a Polk theater system, and it is my first ever. I am extremely happy with the two side speakers, but the center channel speaker appears to be having some issues during certain dialogue and a few other instances.
The audio appears to be hitching at certain points, could someone take a look at this audio snippet and let me know what they think? Oops, looks like the file format isn't supported... hopefully there are a few common tips I can follow anyhow.
I imagine I will try and re-wire it to the receiver, which is the Denon E400. However, I'm hoping someone will have some other ideas on here.
Thanks!
Edit:
To clarify a little bit, it's when the voices are a bit hushed. It's extremely prevalent on female voices.
Post edited by CoilOdysea on
    F1nut Posts: 52,305
    Have you run the calibration program? If so and it's still a problem, you can always go into the AVR to adjust the settings more to your liking.
