Nice Marantz DV 7001 SACD/CD/DVD player can upsample audio
Selling my Marantz DV 7001 SACD/CD/DVD DVD Audio and so on player I am the 2nd owner of this unit. I owned one for many years and then sold it. Ii missed it so found this one and have had it for a while but would like to try something else. It is in great shape and works perfectly There are a coupler of scratches on the top right rear but that is it. Includes the Marantz system remote, power cord and copy of the manual. The 7001 has many great reviews online and is known for its CD playback sound. I can attest to this as in side by sides with some REALLY good CD players I preferred the clean and rich more natural sound of the 7001. Audio and video boards are separated and special attention is paid to audio. I think this is one of the few Marantz DVD players that uses their HDAM units in the audio signal path which probably explains the good sound. Can also upsample audio. It plays every type of disc EXCEPT blu ray. See below. It is NOT a blu ray player The player works as it should and is one of the best I have had at reading bad discs. The remote is the Marantz system remote (controls some integrateds. Built like a tank at 16l lbs Asking $195 or BO Thanks
Specs
General
Available Body Colors
black, silver
Manufacturer
Marantz America Inc.
Remote Control
Type
remote control
Remote Control Technology
infrared
Connections
Qty
1, 2
Type
5.1 channel audio line-out, HDMI output, S-Video output, SCART, SPDIF output, audio line-out, component video output, composite video output, remote control, serial, system components control bus
Connector Location
rear
Miscellaneous
Included Accessories
A/V cable
Black
Power
Form Factor
internal
Audio System
Audio Formats
MP3, WMA
Sound Output Mode
Surround Sound
Video Formats
DivX, MPEG-1, MPEG-2
Photo Formats
JPEG
Digital Audio Format
DTS digital output, Dolby Digital output, MPEG 2 digital output
Frequency Response
4 Hz
Signal-To-Noise Ratio
120 dB
Total Harmonic Distortion
0.0008 %
Dynamic Range
110 dB
Video
Upscaling
Yes (up to 1080p)
Header
Brand
Marantz
Product Line
Marantz
Model
DV7001
Packaged Quantity
1
CE System
Parental Lock
Yes
DVD Features
Picture Zoom
Yes
TV Screen Saver
Yes
Additional Features
JPEG photo playback, auto power off, progressive scanning, video equalizer
Blu-ray & DVD Features
Picture Zoom
Yes
TV Screen Saver
Yes
Additional Features
DVD
Form Factor
tabletop
Built-in Audio Decoders
DTS decoder, Dolby Digital
Type
DVD player
Media Type
CD, CD-R, CD-RW, DVD, DVD+R, DVD+RW, DVD-Audio, SACD, SVCD, Video CD
Media Format
NTSC, PAL
Video D/A Converter
12bit / 216MHz
DVD Repeat Modes
all, chapter, title
Audio D/A Converter
24bit / 192kHz
Media Load Type
tray
Changer Capacity
1
Supported Digital Video Standards
Supported Digital Audio Standards
MP3, WMA
Upscaling
Yes
Signal Processing Features
Upscaling via HDMI
up to 1080p
Cable Details
Type
A/V cable
Included Qty
1
Power Device
Type
power supply
Dimensions & Weight
Width
17.3 in
Depth
13.1 in
Height
5 in
Weight
16.09 lbs
  • verb
    verb Posts: 10,176
    Great deal for someone looking to get into the SACD game. Where was this guy about 6 months ago? :smile:
  • honestaquarian
    honestaquarian Posts: 3,259
    @verb you mean you haven't already bought it?!?!?!? :p;)
  • verb
    verb Posts: 10,176
    Already have 3 SACD spinners! :smile:
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    Wow what a steal!!! These are the ones people think should over $1,000 on the bay. Excellent price! Glws!!!
    Home theater:
    43” Westinghouse Displayer
    Marantz UD-7007 Player
    Emotiva MC-700 Processor
    Adcom GFA-5006 Amplifier
    Parasound Zamp Amplifier
    Ethereal ESO-1 Power Conditioner
    Klipsch RC-10 Center
    Klipsch R34c Fronts
    Klipsch RB-41 Surrounds
    Polk audio PSW-505
    Stereo:
    Polk audio RTA-12c’s fully upgraded crossovers
    DIY 12tc braided speaker cables
    Denon DVD-5910ci Spinner
    Parasound P6 Preamplifer
    Parasound HCA -1500a Amplifier
  • scubalab
    scubalab Posts: 3,105
    Bump for an active sale...
  • rtart
    rtart Posts: 852
    Hi. Does this unit do SACD and/or DSD over HDMI, or are analog outputs required? I have an Oppo DV-980H which will do DSD over HDMI, and might upgrade. thx!
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
    2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
    Denon X3700H Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2100/NZ7 projector
    Silver Ticket 135" microperf AT screen
    Berkline 090 electric recliners with Aura Bass Shakers
  • geppy1
    geppy1 Posts: 3,076
    I will be honest I am not sure I will try and figure it out
    pitdogg2 Posts: 27,383
    There's a note in the manual saying "If you listen to multichannel DVD-Audio through one of the digital outputs, it will be down mixed to stereo. Also, high sampling rate DVD-Audio (192HKz or 176.4HKz) will be down sampled to 96, 88.2, 48 or 44 KHz, depending on the disc. Multi channel and high sampling rate DVD-Audio are only available through the analog outputs. All DVD-Audio and SACD audio are output only through the analog outputs."
    To the best of my knowledge
    there may of been a firmware update that may have made my prior comment not valid, but as it came from the factory no it could not send those signals through HDMI.
  • geppy1
    geppy1 Posts: 3,076
    That is a bingo
  • geppy1
    geppy1 Posts: 3,076
    This has been sold
  • skrol
    skrol Posts: 3,468
    rtart wrote: »
    You may want a spare anyway. I had that same Oppo and it died due to a failed power supply board. Apparently this is a common failure.
    Stan
    Main 2ch:
    HT:
    Other stuff:
