AR 38B Find
Hi,
Just pick up these at the local GW for $4.99 each. The drivers need to be refoam but for the price why not. They are heavy for their size. Will add them to the queue after the 1C are done. I need to get back to work.
Need to look for 4" surrounds for the mids and 8" for the woofers.
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • verb
    verb Posts: 10,176
    Very nice! :smile:
    gudnoyez Posts: 8,174
    edited June 2019
    Great pair of Speakers, I have owned AR 38's AR 58's and currently own a pair of AR
    18's which I rehabbed quite a few years back, spend some time rehabbing those 38's you will be rewarded.
    Tony M Posts: 11,811
    Love getting classic older speakers for cheap! B)
    I should frequent my local thrifts and pawns again...even though I have no space for any new finds. :s :'(
    I just had a quasi re-foaming party here 2 weeks ago on a friends AR410's. 3 of us had a blast on that first day. Then it was just me and the speaker's owner.
    It looks like the ferro fluid has leaked out of your tweeters.
    gudnoyez wrote: »
    VERY NICE! <3
    I've yet to hear that series.
  • Schurkey
    Schurkey Posts: 2,122
    The rotted foam looks just like what I had on a pair of give-away AR93Q I got from folks I know.
    The tweeters had also separated, no more ferrofluid.
    I glued new foams in place, and glued the diaphragm of the tweeter back on (no added ferrofluid) and they work fine for use in a secondary system.
    I did eventually re-install the "sock" grillecloths, and also did a cheapie revamp of the crossovers.
    edited June 2019
    Interesting speakers! Baby AR9's?
    I'll bet both sound GREAT. B)
  • Irrenhaus
    Irrenhaus Posts: 1,105
    Tony M wrote: »
    Yes I am worry about that also on the tweeter but, it can always be fix.
    Cheers
  • Schurkey
    Tony M wrote: »
    Yep, the one with the side-firing woofers.
    My only acoustic-suspension speakers. Everything else I've ever owned was ported in some way
    Surprisingly nice considering the tweeters have known issues (no ferrofluid), the bigass midrange and both bass units have aftermarket foam, and all I did with the crossovers was install fresh electrolytics (not film caps).
    Oh, yeah...I ran the grille socks through the washing machine. Got rid of a heap of tar and nicotine.
    I have about seventy-five dollars in 'em, plus hours of labor.
    I'd love to hear them. B)
    Wouldn't elevating them or tilting them back a bit improve the highs? :p
  • Schurkey
    Tony M wrote: »
    The "new" house has a wider fireplace. These are now parked on top of the fireplace base (I'm sure there's a proper name for it...but I don't know it) so the tweeters are at ear-level when seated. If they were on the floor, they'd be tilted and on spikes.
    The situation is not perfect, but they sound pretty fair. Nicely toed-in for what I thought would be the typical listening position for SWMBO and I. As it turns out, we tend to sit to the side.
    NICE.
    SWMBO... :D
    I just learned what that means.
    Most of us live with our WAF for sure.
    HWHL. ;)
