PSW505 Issues - Plate amp seems to be broken
Hi,
I had bought PSW505 from Newegg on 11/24/2014. It had been working great until I recently noticed it was creating some distortion noise. When I turn on the subwoofer, the red led turns on for a bit and then fades away with some distortion noise. It doesn't stay on.
I contacted Polk support on 12/10/2018. They said it is out of warranty and I need to buy a
plate amplifier.
Is there anything I can do to make it work again. The price of the plate amplifier quoted from Polk was expensive like buying a new subwoofer.
I will appreciate any help or suggestion you can provide.
Thank you.
Answers
    F1nut Posts: 51,913
    Buy a new sub.
  • verb
    verb Posts: 10,176
    I feel your pain @madanthapa as we've all been through the dreaded red light heartbeat issue. Certainly a new plate amp is an easy swap out, but the price as you found out is quite high! I've swapped out a couple of plate amps on my Polk subs in the past.
    Taking your chances on a used plate amp is risky too. You may be able to find one for a deal if you're patient.
    An alternative is upgrading your sub to an SVS or others. I have a couple of SVS subs and love em! And the customer service is excellent!
    Good luck! And welcome! Keep us posted on where your journey takes you!
  • rooftop59
    rooftop59 Posts: 8,120
    madanthapa wrote: »
    Hi,
    plate amplifier.
    Thank you.
    Honestly 4.5 years at the price you likely paid is quite a deal! Save up and do it right this time. SVS and HSU are your best bets for budget, SQ, and longevity!
    Game Room 5.1.4:
    Bedroom 2.1
  • Thank you, everyone, for the quick response. As everyone one suggested I will start looking for a new one.
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    I must be the luckiest psw505 owner ever? Had mine for 8 years and it's still killin it
    Home theater:
    43” Westinghouse Displayer
    Marantz UD-7007 Player
    Emotiva MC-700 Processor
    Adcom GFA-5006 Amplifier
    Parasound Zamp Amplifier
    Ethereal ESO-1 Power Conditioner
    Klipsch RC-10 Center
    Klipsch R34c Fronts
    Klipsch RB-41 Surrounds
    Polk audio PSW-505
    Stereo:
    Polk audio RTA-12c’s fully upgraded crossovers
    DIY 12tc braided speaker cables
    Denon DVD-5910ci Spinner
    Parasound P6 Preamplifer
    Parasound HCA -1500a Amplifier
