Audiophile Flex Seal
F1nut
F1nut Posts: 52,164
edited May 2019 in Speakers
A picture is worth a thousand words.
Not mine!!!
    pitdogg2 Posts: 27,572
    Dayum why didn't I think of that.
    ( smacks forehead )
    nooshinjohn Posts: 26,065
    Maybe worth a try on a torn surround on the unobtainium 15" passives perhaps, but only on the tear itself.
  • BlueFox
    BlueFox Posts: 15,250
    That’s a lot of tape, and I doubt if it is very flexible. Then again, something is better than nothing. :)
    F1nut Posts: 52,164
    BlueFox wrote: »
    Put the pipe down Bud.
    audioluvr Posts: 6,013
    Not mine!!!
    Uh huh. Sure...
  • erniejade
    erniejade Posts: 6,321
    Agree with @audioluvr . We all know your main system was swapped with Realistic speakers.
  • pumpkinman
    pumpkinman Posts: 10,412
    Is it as rare as black paint ???? :)
    Because I am The Pumpkinking
    VR3 Posts: 29,631
    edited May 2019
    my theory is.. this was being applied elsewhere (like somewhere it was designed to be used)… the user had gotten so high from the off-gassing (smells awful, extremely toxic) that he started to look for other places to put it (not designed for it!) :)
  • afterburnt
    afterburnt Posts: 7,892
    My drivers never leak, should I be concerned?
  • afterburnt
    Funny that this came up I was trying to think of other uses for that "Dip Schiit" stuff that you put on tool handles. Now I know what I am going to do with it.
  • kharp1
    kharp1 Posts: 3,453
    You guys are just a bunch of elitist snobs..I see nothing wrong with upgrade.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    I used contact cement on some cracked accordion type surrounds on a pair of 12 inch Frazier woofers that I didn't want to rebuild yet. Worked great since they are ported models that don't have any pressure buildup. Stayed supple for years.
  • Willow
    Willow Posts: 11,310
    Is your coffin leaking sound?
    F1nut Posts: 52,164
    Nah, it's dead quite.
    SCompRacer Posts: 9,153
    Bah, this is what you need to use.
    SCompRacer wrote: »
    I heard about this stuff in legends told around a campfire. Seems this stuff is almost as rare as black paint. BTW, if anyone tells you they have found black paint or this stuff, dismiss their claims as fake news.
