How do you deal with component heat?
How do you deal with hot equipment?
My power amp sits on an open console, has two massive exposed heatsinks and yet runs at ~125°F/50°c (measured with a baby thermometer) at a normal listening level and even at idle.
Feels fairly hot to the touch, I can uncomfortably lay my hand on it for a bit, but the builder says it's running per spec and it should run hot.
Regardless, this freaks me out a bit. First, I placed 4 AC infinity low noise fans between the amp and the component that sits on top, I can "bareeeely" hear it and brings the temperature down ~0°F...
I am wondering if I am overthinking on this?
    Tony M Posts: 11,925
    edited May 2019
  • joecoulson
    joecoulson Posts: 4,943
    I don’t really have to worry about the PS audio equipment, it’s class D and I really don’t ever feel that it’s hot to even when I’ve been cranking it for a while.
    The home theater receiver is a whole other story, it will get hot just watching television at normal levels. The picture below shows a mid-level computer fan set up that I cut into the wood countertop, it is not automatic, yet, but the switch is mounted right underneath the countertop overhang. This works fantastic and has three different levels of speed, the lowest is almost dead silent.
    heiney9 Posts: 25,612
    edited May 2019
    cortico wrote: »
    If it's designed to run hot, then don't worry about it. That's what the heat sinks are for. You start cooling it down and it could affect sound quality as some semi-conductors are designed and sound better running at the proper temp.
    For example Pass class A runs very hot, but in most instances the semi-conductors are only running at 33% of their thermal capacity...........well within spec for normal longevity.
    If the designer/builder states it's normal, then move along. Of course I am assuming it properly ventilated per the manufacturer's recommendation.
    Yes, you're overthinking it unless you are stuffing it somewhere where it doesn't get proper ventilation
    F1nut Posts: 52,241
    If it ain't hot, it ain't worth squat.
    Yes, you are seriously over thinking and get rid of the fans, which are doing more harm than good.
    VR3 Posts: 29,658
    I have all of my stuff in an enclosed cabinet... I have ventilated shelving and I run fans that simply draw the heat up to the top and a fan at the top that pushes the air out... I don't recommend running fans directly on top or below equipment as this will draw dirt and dust through the component which will actually make it run hotter... And there may be sensors in the unit that detect temperature which will be thrown off.
    But agreed, sound alike you are over thinking it
  • kharp1
    kharp1 Posts: 3,453
    I've noticed the Odyssey runs very hot, I suppose it's running class A...didn't realize it was. Haven't felt heat like this since the Pass. Idles very warm, and, is too hot to touch after being put through a workout. I just crank the AC up.
    VR3 Posts: 29,658
    A Stratos should not be running hot, even cranked up in my cubby I would say mine ran no more than luke warm.
    Those big heat sinks are overdone on that thing.
    I'd call Klaus
  • lightman1
    lightman1 Posts: 10,800
    Pour cold beer on it..... Drink the remainder....
  • motorstereo
    motorstereo Posts: 2,401
    My two solutions for class A or kt88 tube amps were to use them during the cold weather or sell them and let the next guy worry about it.
    What is there to "worry" about?
    They are designed to run that way.
  • daddyjt
    daddyjt Posts: 3,207
    As long as your bias setting is reading within spec, no worries whatsoever. Sounds like you’re letting it breathe, so enjoy!
    ― Aleksandr Solzhenitsyn
    Clipdat Posts: 13,101
    If you can't stand the heat, get out of the kitchen.
  • kharp1
    kharp1 Posts: 3,453
    VR3 wrote: »
    I'd call Klaus
    It's not worth the hassle to pack it up and pay to ship a 75lb amp, that's bigger than the average amp, both ways. Play with it till it burns up and sell it for scrap.
    xschop Posts: 5,690
    My Nakamichi PA5 ran so warm that I thought I was on the bad end of a trade. After further looking into it, it is par for course.
    Roasting marshmallows isn't too far fetched lol
    VR3 Posts: 29,658
    edited May 2019
    kharp1 wrote: »
    VR3 wrote: »
    I'd call Klaus
    I was actually surprised at the cost to ship mine to its new owner, was right around $45 insured.
    My Pass Labs amp was running extremely hot, I was glad I sent it off as it was sending some DC to the speakers which would have blown them at a certain point. (Side note: it also did not sound very good)
    Just saying, a phone call is free to make sure it sounds right.
  • kharp1
    kharp1 Posts: 3,453
    I'm pretty sure it's off. I put the sacrificial B&W's on it because I sensed something wasn't right with it. Haven't checked the offset yet. I barely have enough time to survive working like I am. The couple of times I've had a few minutes to listen to it I've noticed the amp sounds "hot" like the gain is too high. I changed the gain on the pre and it improved, but, still not right.
    EndersShadow Posts: 17,746
    Your a 3 hour trip or less to Klaus... save the shipping and just come for a visit to his shop to drop-off and then pickup.....
    Get all the piece of mind of knowing no one manhandled it and also get to meet the man himself.....
  • kharp1
    kharp1 Posts: 3,453
    Well, I lost my license start of the year.
    pitdogg2 Posts: 27,684
    kharp1 wrote: »
    See you'll drive the speed limit and safer....
    Maybe have some whiskered furball of a bucket truck driver stop by for a beer.
  • motorstereo
    heiney9 wrote: »
    This little tidbit from my owners manual.
    mhardy6647 Posts: 35,456
  • cortico
    cortico Posts: 587
    Thanks, folks. The amp runs Class A operation up to >6 watts output (most of the listening); Class AB-1 thereafter.
    It's pretty toasty, I guess I overreacted adding the 4 5inch fans. It's within spec, I will hope the manufacturer expected 25 plus longevity...
    @mhardy6647 nice, funny enough, I never worried about the 6V6GT heat on the guitar amp, which should be well over 400°F
  • kharp1
    kharp1 Posts: 3,453
    I checked the DC offset on the Odyssey this morning after I got home from work...and went next door and borrowed back my Fluke. It was very low, no issues there. I think it's just a mismatch issue with the gain of the pre.
  • BlueFox
    BlueFox Posts: 15,250
    kharp1 wrote: »
    Yikes! For how long?
  • kharp1
    kharp1 Posts: 3,453
    BlueFox wrote: »
    kharp1 wrote: »
    As of now it's for 18 months. I go back to court at the end of June, we'll see what happens then.
  • cortico
    cortico Posts: 587
    edited May 2019
    Would you care to adjust bias so it measures the same on both channels?
  • codycatalist
    codycatalist Posts: 2,661
    That isn't far off enough for me to consider adjusting the bias. If we were talking 15+ mayyyybe.
  • cortico
    cortico Posts: 587
    I have set the idle current on both channels at 18MV the across the emitter resistors measured after the amp stabilizes, the heatsink temperature measure ~45celcius, when the amp is opened. (spec is 20mv -/+2 heatsink 40-45c)
    After the hood is back down, and with another component on top, temperatures raises up to 51celcius.
    It just feels as hot as a car engine or like a radiator... I need to get used to this.
    F1nut Posts: 52,241
    Why are you putting another piece of gear on top of your amp? That's a no-no.
