Remote control issues
stuker71
I have the Polk 9500BT, I've got several questions.
1. How do I stop my other remotes from interacting with the Sound Bar. For example if the sound bar is on and I turn the tv off, the sound bar changes the source, or if I try to use my Android box remote it changes the source on the sound bar.
2. Why does my Sub seem to kick in and out, especially noticable when listening to music
Answers
I would suggest turning off the CEC option on your sound bar maybe.
Have you actually heard the sub cut out while listening. Do you typically listen at low volume? -
Yes Ive heard it cut out, it's quite noticeable when all of a sudden there is no base. It doesn't seem to matter what volume level I listen at.
Any idea how to turn off the CEC option?
