CRS+ 4.1TL upgrade - best bang for my buck?
Picked up a near perfect pair of CRS+’s from 1990 this week for $125. They sound fantastic as they stand, but I’m thinking about going all in on these, unfortunately, I’m not a rich dude. Any recommendations or suggestions for upgrading to 4.1TL? What caps would give me the most value/performance for a reasonable budget? In order of importance, after tweeters and refreshing xovers which mods yield the best and most noticeable performance improvements? As always, I appreciate everyone’s help!
Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL (198’s), R100's, R200’s, R300 🤩
Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5B (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (4x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA1(mod to “a” & SL1000 Wuhan mod), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
  • monepolk
    monepolk Posts: 1,154
    Great deal on some nice looking speakers.
    pitdogg2 Posts: 27,578
  • JayMX
    JayMX Posts: 460
    Wood shims?
    Nope, they’re cardboard. I think they’re probably original packaging to protect the bezels... these boxes are like brand new!
    edited May 2019
    JayMX wrote: »
    Wood shims?
    Gotcha makes sense. You should run like you stole'em... very nice. Take your time and do them right. Sonicaps or Clarity would be my only two choices.
    Toolfan66 Posts: 18,292
    in with 36, I will even cover shipping..
    xschop Posts: 5,665
    Those are so nice, even I wouldn't chop anything on them. Well, tweeters couldn't stay.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Congrats on your good fortune. I don't think you can replace the tweeters with the RDO-198, unless you modify the x-overs as well. Although I may be wrong. This pair is worthy of any and all mods you afford, take your time and enjoy the process.
    gudnoyez Posts: 8,183
    edited May 2019
    Those are beautiful enjoy them. I have everything I need for mine even the OEM stands except the rebuilt crossovers that's all I need. Start by trying to source Larry's rings and tweeter brackets the rest is easily obtainable, the RDO 198s then the crossover upgrade and you will be set. I would leave the cabinets as is they are gorgeous.
    4.1TL is the upgrade to use RD-0198 correctly. This was sanctioned by Polk and would have been implemented had they gone forward with SDA's
  • tonyp063
    tonyp063 Posts: 1,147
    Before you do anything you anchor the mid-woofer magnets. Plenty of threads here on how-to.
    The TL mod is going to require you to do tweeters and crossovers at the same time.
    For *decent* caps & resistors you will be looking at roughly $100 per speaker. You can spend way more. You can spend a little less.
    But good components ain't cheap & cheap components ain't good.
    Then the tweeters at whatever they cost at the moment. $50 each?
    Those are your rough do-it-yourself base costs. You asked.
    After that, there are a bazillion little things you can do that will make them that much better.
    Your call on how deep down the rabbit hole you want to go. Good luck, you'll need it.
    Opinion:
    Were it me and had I found a pair of CRS+ in that condition, I would be opening my wallet in a big way.
  • Mike Reeter
    Yes, I was just under the impression that the x-over had to be modified (the 4.1TL upgrade) to accept the RDO-198. If not, one would have to use the RDO-194 "if" they only wanted to change the tweeters and not change the x-overs. I didn't do a very good job of that in my first post.
  • codycatalist
    codycatalist Posts: 2,661
    For what its worth I went sonicap in the high pass and dayton in the low. I have no complaints.
    Is it worth upgrading the sub bass inductors on these?
  • westmassguy
    westmassguy Posts: 6,850
    Yes
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • JayMX
    JayMX Posts: 460
    Yes
    What is the improvement with this upgrade?
    Better bass and more articulation in the bass. Some of the Polk inductor's were all over the place. When original inductors are measured they could be way off from each other. When buying new it is advised to make sure they are correct. When I bought mine from Erse they both were labeled correctly but one had been mis-marked and was WAY off from what it should have been. You could also measure all yours in the speaker and balance them all as close as possibly to each other if money is tight.
  • westmassguy
    edited May 2019
    JayMX wrote: »
    Yes
    Improved deep bass, starting around 150 Hz downward. Polk intentionally kept the DC Resistance high on theses Inductors, to keep the overall Impedance of the speakers acceptable. Amplifiers capable of powering 4 ohms or less were very pricy back in the 80s.
    Keep in mind, this only affects the dimensional woofer. By lowering the DC Resistance, the dimensional woofer can produce the same in-phase deep bass as the stereo woofer.
  • JayMX
    JayMX Posts: 460
    edited May 2019
    @westmassguy thanks! What is your recommended mfg/supplier for the inductor?
  • Dr_Wu
    Dr_Wu Posts: 356
    JayMX wrote: »
    Yes
    Thanks for the knowledge, @westmassguy. So, with a powered sub, maybe not as critical an upgrade?
    audioluvr Posts: 6,014
    edited May 2019
    Dave did my crossovers using the Sonicaps for the high pass and I had him do the Daytons on the low pass so I could afford to have him tune me some inductors. Very happy with this budget combo.
  • westmassguy
    JayMX wrote: »
    http://www.erseaudio.com/Products/SuperQCoils16Gauge/ESQ55-16-18000
    https://www.parts-express.com/jantzen-audio-16mh-14-awg-c-coil-toroidal-inductor--255-842
    The Erse will have to be unwound to 16mH
  • westmassguy
    edited May 2019
    Dr_Wu wrote: »
    JayMX wrote: »
    Yes
    For this model, yes.
  • JayCee
    JayCee Posts: 1,509
    edited May 2019
    @JayMX...congrats, nice pickup.
    I'd also Dynamat the drivers and consider Blackhole (not sure if still produced) or similar product . You can use Noico, same affect as Dynamat, and claims to be thicker at 80 mil's. Used it before and ordered a box last night for a pair of 3.1tl's I just picked up. At $22 for a 10 sq ft box it will be plenty.
    https://www.amazon.com/Noico-deadening-Automotive-Insulation-dampening/dp/B01KZ5X7KO
    Hurricane nuts (Larry's rings aren't available) are also recommended.
    I have a pair of CRS's I acquired several years ago and modded to 4.1tl; to include all suggested upgrades. I have more SDA's than rooms at the moment but will always keep the 4.1's as backup if I have to downsize my home many years from now. Add the Dreadnaught and these speakers are killer considering their size.
    Soundstage is tremendous. I have a an Epik dual 15" subwoofer that I've run with these in my home theater. Really wanted to like a pair of 705's I had but the 4.1tl CRS's were more to my liking. Gifted the 705's to my sister.
    Have fun....you'll really enjoy them.
    Post edited by JayCee on
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • JayMX
    JayMX Posts: 460
    JayCee wrote: »
    ...You can use Noico, same affect as Dynamat, and claims to be thicker at 80 mil's. Used it before and ordered a box last night for a pair of 3.1tl's I just picked up. At $22 for a 10 sq ft box it will be plenty.
    ...Add the Dreadnaught and these speakers are killer considering their size.
    Thanks for the Noico lead. Never heard of it before!
    Regarding Dreadnaught, I’ve always wondered what the benefit of the high wattage (800-1000VA) torroid provides for sound quality? I understand the need for isolation running monoblocks, but what does it do for you sonically?
  • JayCee
    JayCee Posts: 1,509
    edited May 2019
    Increase in mid-bass response and big bump with the soundstage. Search for DarqueKnight's posts, among others, for more technical explanations. Also, read the SDA whitepages by Mathew Polk posted on this site. Essentially, brings the speakers more in-line with the original technical specs but not realized because of 1980's power amp limitations; not liking dips in the 4 ohms or lower range.
    F1nut Posts: 52,166
    JayMX wrote: »
    JayCee wrote: »
    Mo' better sound. Everyone who has added a Dreadnought regardless if using a common ground amp or non-common ground amps has reported a noticeable improvement in sound quality.
  • JayCee
    JayCee Posts: 1,509
    Mo' better sound.
    What he said :smiley:
  • TennMan
    TennMan Posts: 1,266
    Does this have to be dead on or is there some tolerance on how much it can vary some from 18mH?
  • westmassguy
    TennMan wrote: »
    I wouldn't deviate more than 5%, otherwise you alter the design.
  • TennMan
    TennMan wrote: »
    Thanks! Obviously I meant 16mH. 18mH was a typo.
