Harmony 350 or 665 remote
Hello,
The volume buttons for my Onkyo PR-SC886 remote are giving out so I need a universal remote. How are either of these? Compatibility with Oppo BDP-103D and my seldom used JVC VCR is listed as well as my Outlaw 1050. But can it be programmed for both an AV pre-amp and a receiver at the same time. Are these good choices or should I look at others.
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,138
    I wonder why it's always the volume button that stops working?
    Harry / Marietta GA
  • FestYboy
    FestYboy Posts: 3,861
    Have you cleaned the pads and circuit board yet?
  • rooftop59
    rooftop59 Posts: 8,120
    jimbo1421 wrote: »
    Hello,
    Jim
    Yes it will do everything you need. Highly customizable. I use this one, which is an upgrade if you have a smart phone:
    https://www.ebay.com/itm/Logitech-Harmony-Smart-Control-Works-With-Alexa-Or-Google-Assistant-New/202649341415
    Game Room 5.1.4:
    Bedroom 2.1
  • Jimbo18
    Jimbo18 Posts: 2,351
    I have a couple of the 350's, because I didn't like the small screen on the 650, and prefer using just buttons. Very happy with them. Just depends on how many components you need to control.
    pitdogg2 Posts: 27,918
    Most used
  • jimbo1421
    jimbo1421 Posts: 772
    FestYboy wrote: »
    Alright! This worked. A little IPA (isopropyl alcohol, not India Pale Ale) with a Q-tip did the job. I found some take apart instructions online and only broke off a few tiny plastic bits getting the remote apart. It went back together with a little difficulty, but now it works fine, volume and all. With a little practice, I could get a job at the Onkyo factory. Thanks, FestYboy.
    But if I still decide to get a Harmony remote, do they handle the menus and set up functions well?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • rooftop59
    jimbo1421 wrote: »
    FestYboy wrote: »
    Jim
    Yep! You can fine tune it to your heart's delight, but it usually does all the major functions without much extra effort.
    Game Room 5.1.4:
    Bedroom 2.1
  • jimbo1421
    Thanks, rooftop59. That's good to know.
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
