quick and easy bbq(smoked) chicken
marvda1
marvda1 Posts: 4,903
edited April 2019 in The Clubhouse
i read somewhere a restaurant was close to a store that did rotisserie chicken and they would go out the backdoor, bring in the pre-cooked rotisserie chickens, put bbq rub on them and smoke them. they would also jack up the price and sell them as bbq chicken.
today thought i would give this a try and it came out great. the chicken was still juicy with great smoked flavor. this will be my go to from now own as it doesn't take much time and you get plenty of compliments :D
Puritan PSM156
    pitdogg2 Posts: 25,652
  • rpf65
    rpf65 Posts: 2,127
    Remember hearing a similar story from a couple years back that was similar. In that case some trendy restaurant was buying chicken from a Popeye’s down the street.
  • afterburnt
    afterburnt Posts: 7,892
    how are you smoking them?
  • marvda1
    on my offset smoker, cooked some hot links also. it only took 1 chimney of charcoal and a split of pecan wood and no more than 30 to 40 minutes. i told my guests i was up at 3 am to start cooking, of course my wife told them i was fibbing >:)
    Puritan PSM156
  • aprazer402
    aprazer402 Posts: 3,149
    Great idea. I'll have to try to that with one or two of the large 4 lb. birds from Sam's or Costco. Usually juicy, but kind of bland. Sometimes they're undercooked near the bones anyway. Thank you.
  • afterburnt
    marvda1 wrote: »
    Ha, I have a similar story. I told my guests it was chicken.
  • afterburnt
    @marvda1 how long does it normally take to smoke a chicken in that rig?
  • marvda1
    i do pieces, but it should take anywhere between 1.5 to 2 hours depends on the temp you cook at. the thing is you will get the smoke flavor but it is hard to get the seasons flavored throughout the chicken unless you brine, inject, or season overnight. it's also a _itch to get the skin tender or crisp the rotisserie chicken has tender skin plus because of the way it is cooked the seasonings penetrate the meat.
    Puritan PSM156
  • Gerres26
    Gerres26 Posts: 864
    It's been my experience to get chicken or turkey skin crispy after smoking is to raise the temp and place the bird directly over the heat for a short period...but be careful as you don't want it to burn. I treat chicken wings the same way and they always come out with a nice crispy skin as well.
  • afterburnt
    @marvda1 I will have to try this, on unsuspecting guest. I usually get up pretty early to smoke stuff and I don't like that.
  • dromunds
    dromunds Posts: 10,022
    Smokin’ your lunch, huh? I knew some guys who used to do that.
  • afterburnt
    dromunds wrote: »
    I like to wake and bake
    afterburnt wrote: »
    dromunds wrote: »
    Those were the days. Round 2 about 1:30ish....
  • afterburnt
    afterburnt wrote: »
    dromunds wrote: »
    I don't indulge since they made it legal, what fun is that?
  • codycatalist
    codycatalist Posts: 2,662
    afterburnt wrote: »
    dromunds wrote: »
    After a nap at 11.
