Polk SB1+ sound bar and subwoofer
Skip1950
A popping noise is coming out of the system. What is the solution?
Thank you
Thank you
Answers
Hammer
You're welcome -
Skip1950
Check to see if your voice is max volumn if so set it down a notch or two this should fix the popping noise -
While attempting to set up my sb1wifi to Alexa on my fire tv and phone app was un-successful now after 30 seconds of play sb1turns off I unplugged it overnight and when plugged back in it still off in 30 acts like it’s still searching for WiFi
Someone please help -
I think this may have worked. I did have the voice control at maximum. Thank you very much.
