Audyssey is WEIRD
Hello,
So over a week ago I was just playing around and flipped the phase switch on my sub to 180 and got a big hello from my sub https://forum.polkaudio.com/discussion/186251/sub-phase#latest.
I had to take this week off (just burned out). I ran Audyssey with the phase @ 180 and the bass went back to how it was. Flip it back to 0 and boom back to awesome. I also tried using the sub crossover vs the AVR with the same outcome. For whatever reason audyssey is setting the sub out of phase.
Don't get me wrong my system sounded good before. After just flipping the switch it's like WOW. The wife and I watched a movie, in 3 minutes she was asking what did I add.
Best results I've found is to set the sub to use it's C/O, run Audyssey @ phase 0 and when done just flip the switch to 180.
Certain flavors of audyssey calibrate the subs, that being the newer versions. Calibration programs aren’t perfect
Many people, using all versions of calibration programs see a speaker out of phase warning when nothing is wrong, not surprising a sub can be calibrated out of phase.
Many sub companies will advise making certain adjustments after running a calibration program for similar reasons you have experienced. It’s a good idea to use any calibration program as a base line, record the settings, and tweak the settings a little.
Glad to hear that your experimenting with your AVR to try improving the sound.
This being a music oriented site, not much discussion on HT related issues. My current AVR, Yamaha, has similar calibration issues, but playing around with different settings seemed to get better sound, at least to my ears.
There are reasons the calibration programs aren’t perfect, and those can lead to multiple threads, but overall they are pretty good. No way those engineers can design a program for every imperfect room that we all have to deal with. -
Maybe not your issue but I thought audyssey and the like, calibrated the sub -10db (75db) under reference (85db) to compensate for the +10 bump on Dolby formats. Also the reason for dynamic eq algorithms is to bring the sub levels back up to enjoyable levels.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
After the calibration, what do your subwoofer levels come out to for 0 phase and 180 phase? Are they different? When you calibrate it with 180 phase is Audyssey just setting the level lower? If so, just adjust it up. Most people bump up the subwoofer level after the Audyssey calibration._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
in either 0 or 180 Audyssey sets the sub @ -5db. It sounds darn good off the bat. Flip it over to opposite the calibration setting and there is a ton more bass. One thing is if I just leave it the sub is a tad localized. flip the switch and bammmmm a ton more bass and no localizing of the sub at all.
My wife and both of the kids have even said how much better it is.
Just weird audyssey setting it all up like that.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
All that matters is that it sounds good to you. Until you experiment you never know. Glad you found a setup you're enjoying._____________________________________________________________________________________________
DAC: Bricasti M1SE
