WHAT OTHER SPEAKERS???
Hi Polk SDA lovers
If you love Polk SDA then what others used speakers under $600 you will consider listening to?
Polk SDA 1C and CRS+, Klipsch Forte II, Focal Chorus 706, Sansui: 9090DB, Eight Deluxe, AU-9900; Pioneer SX-1010, Marantz: 300DC, 3200B, 2325, 2275, Thorens TD-145, Technics SL-1650, Pioneer PL-707, Pioneer RT-707
  • BlueFox
    BlueFox Posts: 15,250
    Good question. $600 is a low bar.
    nooshinjohn Posts: 26,109
    For very near that figure you can get Magnepan's new LRS model. Depending on your listening habits a sub might be needed as well, but reviews are saying the bass performance is pretty good. I had their predecessors, the MMG and love them.
    audioluvr Posts: 6,055
    I'm assuming your price point is for unmodified. Well I like my Klipsch KG4's but just not near as much as the SDA's. For $600 you'd be hard pressed to find anything with the potential as SDA's Just my 2 cents worth though.
  • motorstereo
    motorstereo Posts: 2,413
    Older ADS speakers have a smooth non fatiguing sound that work well for me when I can't listen to my Polks.
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,028
    Sanjib, if you are looking for speakers, DollarDave posted fully modified SDA 2B's for sale at the end of February. He never posted that the speakers were sold. He is in the Houston area.
    https://forum.polkaudio.com/discussion/185664/polk-sda-2btl-s#latest
    Harry / Marietta GA
  • pglbook
    pglbook Posts: 2,265
    Polk Monitor 10s and Monitor 7s. PSB Stratus (any of the Stratus models).
  • codycatalist
    codycatalist Posts: 2,661
    I have 2Bs and the above is the route I most likely am going to take. What do you like to listen to? That can dictate which speakers may work best.
  • pumpkinman
    pumpkinman Posts: 10,445
    I like Boston Acoustics A200’s. They can be found for way under $600. That being said stick with the SDA’s
    Because I am The Pumpkinking
  • Sanjib_a
    Sanjib_a Posts: 62
    Which ADS model you prefer and listen to?
  • Sanjib_a
    Sanjib_a Posts: 62
    Wow! But it is very far from me. I am in the Philadelphia area!
  • Sanjib_a
    Sanjib_a Posts: 62
    Hi codycatalyst
    I mostly listen to Jazz, Blues and Classical.
    Grab the Maggie’s and don’t look back.
  • motorstereo
    Sanjib_a wrote: »
    My favorites out of the dozen or so ADS models I've had go through here are the 1530's. Depending on your room size there's really not a bad sounding model right down to the little 200's,
  • codycatalist
    I agree with John. Grab the Maggie's.
  • gyosa
    gyosa Posts: 770
    I’m dying to hear the new Maggie’s ....
    $650 ! Sounds like a steal !
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
