Grills-On or Off?
imsjry
imsjry Posts: 120
I know I know...but after all these years of high end home audio, I was wondering if there is a general consensus on keeping speakers grills on or off? I have to assume the manufactures test the sound quality designed with the grills on..but maybe not?
  • gce
    gce Posts: 2,158
    Use your ears.
    Anaheim Hills CA,
    pitdogg2 Posts: 27,572
    imsjry wrote: »
    Manufacturers are no different than you. Some voice their speakers with grills on others grill off.
    Only you can make the ultimate decision as to which sounds best to your ears.
  • imsjry
    imsjry Posts: 120
    It just always seemed odd to me they would manufacture speakers with grills that might pose a hindrance in audio quality. I assumed people had their grills off strictly for visual aesthetics (myself included).
    mhardy6647 Posts: 35,392
    I don't's gots no grilles...
    24051079897_52426f965b_b.jpgDSC_9984 (3) by Mark Hardy, on Flickr
    I think the case can be made for the grilles as removable covers to protect the drivers from dust and -- you know -- fingers and stuff.
    There's no doubt in the olden days loudspeakers were meant to be used avec grilles; nowadays it's less clear. Heck, they're optional at extra cost on some loudspeakers nowadays.
  • halo
    halo Posts: 5,619
    My KEF Q150's don't include the grills when you buy them new. KEF sells them but they must be purchased separately. So, I don't use grills with these speakers.
  • verb
    verb Posts: 10,176
    I like the look of grilles off. Makes it look more interesting, IMO. The SRS's look impressive with all the drivers exposed, and the massive PR. Or the look of the Klipsch speakers with the copper colored drivers. :smile:
  • mlistens03
    mlistens03 Posts: 2,767
    My KEFs are one of the speakers Doc Hardy mentioned, the grills were an extra $25 and there was no white option to match the white finish. I decided that if I know there were gonna be little kids around, I'd switch quick to my Dad's Bostons that I am storing, since they have grills and still sound pretty good. :)
    And on some speakers, it doesn't really matter, my KEF's tweeter has a waveguide/armor:
    Picture looks a little weird because they are playing at the moment, but you can see what I'm talking about.
    But yeah, like others said, let your ears decide. :)
  • BlueFox
    BlueFox Posts: 15,250
    Grills are to protect the speakers, not enhance the sound. Many Magico speakers do not have grills. The S series does, but for protection. I take my grills off when I listen, and you can hear the improvement with grills off.
    F1nut Posts: 52,164
    If they come with grills they stay on. Besides, if you're looking at the drivers while listening you're not really listening.
    Clipdat Posts: 13,101
    I leave mine on to block dust from getting on the drivers.
    I do detect a slight, but perceptible, difference in the sound with grilles off vs on.
    However when they are on, I feel more content and at ease. So I just leave them on.
  • tophatjohnny
    tophatjohnny Posts: 4,189
    Amen!
    verb wrote: »
    Hmm...
    Maybe @verb is ready for... Kabuki ;)
    (all borrowed images, Gott sei dank B) )
  • Emlyn
    Emlyn Posts: 4,871
    Since stereo speakers create an illusion, having speaker drivers visible can distract from that. Good speakers themselves are designed to acoustically disappear. When I got my LSiM 707s the big grills kept sliding off the magnetic attachments. I tried them without grills for a week then decided to apply a permanent fix by putting velcro attachment points on the grills and cabinets. Looking at drivers when listening bothers me.
    Those Kabuki speakers were designed to be looked at, not listened to. Mirror imaging a pair for stereo would have been unnecessary work. Worked for Quadrophonic sound maybe. :)
  • imsjry
    imsjry Posts: 120
    I will say visually, I like to look at the drivers vs grills. Any perceived audio enhancement i always assumed was a placebo effect just by nature of seeing the drivers looking at you. I like the mindset that the speakers should seem invisible. Interesting to read these opinions!
  • verb
    verb Posts: 10,176
    verb wrote: »
    Hmm...
    Yeah Baby! :smile:
  • steveinaz
    steveinaz Posts: 19,546
    It depends on how they were designed/engineered. Often grills are provided simply for protection or esthetics.
  • cfrizz
    cfrizz Posts: 13,415
    I always leave mine on, I'm supposed to be focused on the music/movie not looking at my speakers. They are there to provide sound not be looked at.
  • BlueFox
    LOL. Why aren't some of you listening to music instead of looking at the speakers?
  • afterburnt
    afterburnt Posts: 7,892
    Grills on unless my green army men are repelling down my speakers, then I like to see em get blasted when they try to get past the drivers.
  • codycatalist
    codycatalist Posts: 2,661
    Grills on because they are SDAs and that's the way they were intended to be listened to.
  • kharp1
    kharp1 Posts: 3,453
    How you supposed to cook if you don't turn thr grill on?
  • BlueFox
    Listening to tunes.
  • K_M
    K_M Posts: 1,631
    Depends on the speaker.
    Some grilles do alter the highs a good bit, but not just in amplitude, but create peaks and valleys in the treble region.
    Measure the response with grill on and off. If it just reduces the treble a tad, which most do, then decide with ears.
    If it creates several peaks and valleys, (due to diffraction) then better to remove them.
