SDA and room correction...?
To all you guess that have SDA's and room (DSP) correction.
Are you running your room correction with or without the SDA side hooked up?
Run the room correction without the speaker interconnect cable attached.
I would think you would want to run it with the IC cables hooked up. Otherwise you are loosing the additional bass and mid outputs of the SDA side and would get an inaccurate reading.Gustard X26 Pro DAC
Sometimes the phasing plays havoc with some room correction software. Regardless you may still have to adjust some after software is ran. -
Ok...I ran it with it hooked up and made a profile like that. Sounds really good!
I'll run it again with it unhooked and see how it looks and sounds. I'll make another profile so I can compare on the fly.
I was just wondering what you guys were doing.
Thanks -
I've never been able to get a satisfactory result either way for music with either of my SDA's.
For movies it works great.
For music I just put it in pure mode. -
