Recommended cables for HT setup
Hi there,
It has been a while since I posted.
I bought some new Anthem gear for my Polk speakers and now on to the next challenge, hooking it all up.
My understanding is that for speaker wires for my center channel and my RTiA9s, I should be looking at 14 gague speaker wire. Does it matter what brand they are? Should I be looking at anything in particular ?
Basically same question for HDMI cables, power bars / surge protectors, I've seen a lot of folks recommend AudioQuest/Panamax.
And lastly, XLR connectors, worth it? if so what am I looking at when buying? Prices seem to vary for same length but not sure why..
  1. Speakers
  2. center — CSi A6
  3. fronts — 2 x RTi A9
  4. rears — 2 x RTi A3
  5. Ceiling — 2x RC 80i
  6. Subwoofer — SVS PB-3000
  • Amplifiers
  • Anthem A5
  • Anthem A2
  • Marantz AV-7704
  • BlueFox
    BlueFox Posts: 15,250
    I would never use any speaker cable less than 12 gauge. Even if only lamp cord.
  • mantis
    mantis Posts: 17,563
    The reason most people say go with Audioquest and Panamax is that it's very good stuff. I'd say stick to that plan.
    Dan
    VR3 Posts: 29,555
    Have to throw out the supra Rondo, tin plated copper, super flexible. Sounds excellent and easy to work with. 13 awg, close to this coveted 12 awg being mentioned. 😜
    I use their wiring throughout my ht, speakers, hdmi, ethernet, power, no issues or complaints!
  • mrloren
    mrloren Posts: 2,474
    The quality of the speaker wire matters more than gauge.
    Here is what I've used in the last 5 years
    #1 Audioquest type 4
    #2 Doug's Furez https://douglasconnection.com/Raw-Speaker-Cable_c33.htm
    #3 Monoprice/Amazon Basic 12awg.
    HDMI
    I only go with Audioquest
    Interconnects (RCA)
    Audioquest
    Dougs
    SVS Soundpath
    I have no experience with XLR cables
  • pelhamplace
    pelhamplace Posts: 111
    If you were using douglasconnection what grade would be good starter cable (I.e., price per foot)?
    F1nut Posts: 52,023
    Do you price your speakers or AVR by the pound? Of course not, so why the hell do people think it's ok to price cables, which are a critical part of any system, by the foot!?!
    RTIA9's- use 12 gauge from the likes of Audioquest, Douglas connections, Signal cable.
    Center you could use 14 gauge but don't go any less.
    Subwoofer ??- You could use any brand cable, but Audioquest makes decent ones too.
    Surrounds can be 14 or 16 gauge, since they are just ambient sounds.
  • delkal
    delkal Posts: 764
    edited July 2019
    Probably because with AV its a lot of feet to those small rear surrounds..........If you buy the best cord all around you will be spending 80% of your budget for the two speakers that do the least. I would recommend going the other way and budget 80% for better cables for the mains and center. For most any cheap 12 ga wire (including lamp cord) will be OK for the rears.
  • mrloren
    Furez 12AWG. great cable for the price
