Exploring "professional" XLRs and RCAs
    audioluvr Posts: 6,079
    Tony M wrote: »
    Do you guys and gals believe in the directional style cables? YES
    Have any of you reversed the cable's direction the arrows point towards on those type of cables JUST to see if the sound changes? YES
    When I first got my Wireworld Mini-Eclipse' I was doing A/B comparisons and inadvertently got one swapped the wrong way and the first thing I noticed was a shift off center. There is a significant amount of research on speaker cables done by many companies for decades. Gotta be some benefit going on there somewhere...
  • erniejade
    erniejade Posts: 6,327
    You might want to also look at DH labs air matrix xlr on the used market. I have seen them go for 90-150.
    Clipdat Posts: 13,105
    Thanks for the tip. Not planning on purchasing any other cables at the moment, but this is not the first time I've heard good things about DH Labs cables.
    VR3 Posts: 29,756
    The Air Matrix, IMO is on the best out there.
  • joecoulson
    joecoulson Posts: 4,985
    I’m very happy with my Colorado’s. They are not entry level however but if you can find for $400 or less, grab some!
  • Tbone289
    Tbone289 Posts: 661
    edited May 2019
    I build my own directional ICs out of Mogami Neglex 2534 and Neutrik gold XLRs or Neutrik gold RCAs for SE connections, and they sound great to me. This is a very inexpensive route to go with high quality components if you have any soldering skills. It's also a great way to try out different components without emptying your pockets.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
    mhardy6647 Posts: 35,562
    Tbone289 wrote: »
    FWIW I've recently done this as well (albeit, at least so far, with a cheaper, shielded Mogami cable) :)
    PS @Tbone289, quick -- post something else; that was apparently your 666th post, and that's scary! ;)
  • tophatjohnny
    tophatjohnny Posts: 4,189
    Tried a lot of top flight cables and found the Nordost Frey 2 rca's to work best for my ears.
    Over $1k for a .6m pair, I would hope so! ;)
  • BlueFox
    BlueFox Posts: 15,250
    What is a ‘professional’ cable? Unfortunately, because it is a limited market, and good cables are handmade, good cables will be ‘expensive’ compared to cheap, mass produced cables. Basic economics.
    BlueFox wrote: »
    https://en.wikipedia.org/wiki/Professional_audio
  • BlueFox
    So, that has zero to do with home stereos.
    You asked what a "professional" cable was. I answered succinctly.
  • BlueFox
    These guys sell professional cables -- and I've bought a bunch from them (XLRs mostly).
    https://www.markertek.com/
    I've finished my listening tests and notes for the 4 XLR cables! Now to collect my thoughts and write up a coherent shootout review!
    Special thanks to my friend @joecoulson for providing the AQ Red River XLRs for this review, I sincerely appreciate it.
    edited June 2019
    Tonight I started the RCA portion of my listening tests, with the Kopul RCAs to connect my CXN v2 to the pre: https://www.bhphotovideo.com/c/product/1023115-REG/kopul_src_4003_stereo_rca_cable_3.html
    First impressions are good, very good.
