SurroundBar SDA - program Harmony Smart Control remote
We have the old school SurroundBar SDA and are trying to program a Logitech Harmony Smart Control remote (uses a hub) to operate the Polk soundbar. Anyone had success with this? I am aware the soundbar uses IR but the Harmony is supposed to be able to work with any type signal, or so we thought. Thanks for any help!
Answers
  • Mikey081057
    Mikey081057 Posts: 7,127
    Mine just selects a generic device called Polk Amp in the logitech setup and it works
    Garage | Polk Monitor 5B's
  • joysjunk
    joysjunk Posts: 2
    Is your soundbar the older model specifically called SurroundBar SDA? Harmony setup makes me pick Polk Audio then also pick a model, which is SurroundBar SDA. After doing that, it still will not allow the hub to power it on. In the past, this particular soundbar relies on the Learn/Remote button to program any remote and then you have to hold it nearby etc. I also tried that with the Harmony remote, but the Harmony remote itself is RF (I believe) and relies on the hub to send the IR signal to the device (again, I believe I understand it to be this way). I’ve tried “teaching” the hub as a workaround and so far no luck with that approach either.
