SL6000 and SL6500 tweeters
Question, where will I be able to find the specs for these tweeter? I’m wondering if there’s any difference?
  • skrol
    skrol Posts: 3,487
    Dang, I have specs for the SL-6001 and the SL-6503. There is a difference between these two for what it's worth:
    SL-6001
    * Size / Type = 3.75" Tweeter Dynamic Balance® Trilaminate Dome
    * SPL = 91 db @ 1w/1m
    * Wattage = 45 Watts RMS / 90 Watts Peak
    * TriLaminte Dome Tweeter
    * Response = 1600 Hz. to 25 kHz.
    * Weight = 1 pound ea.
    * Magnet = Un-Shielded
    * VC = 1"
    * Ohms = 8 ohms
    * Markings both the SL6001 and BD0113-A part numbers are on the tweeter.
    SL-6503
    * Size / Type = 3.450" Dynamic Balance® poly dome tweeter
    * SPL = 92 db @ 1w/1m
    * Wattage = 40 Watts RMS / 80 Watts Peak
    * Polymer dome tweeter
    * Response = 1.5 kHz. to 21 kHz.
    * Magnet =Un- Shielded
    * VC = 1" ( 25 mm)
    * Ohms = 8 ohms
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • cortico
    cortico Posts: 587
    Thanks, I can't find any info either, they all look Identical in shape...
    I like to have a couple of replacement drivers of out of productions speakers, just in case...
    I will contact Polk CS for more info.
  • boston1450
    boston1450 Posts: 7,758
    I tried also with no luck. What speakers did they come out of ? (i didnt see listed) i will try again. Maybe try looking that way- might come upon something
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • cortico
    cortico Posts: 587
    My speaker (LS70) came with SL 6000. I found a SL6500 with a tag that says LS-FX) my gut feeling says it would be fine... I doubt there are many variations....
  • boston1450
    Got a fair amount of Read On them & thats about it. Why Polk make things so hard
    Randy-Maine
    by David WMG
  • cortico
    cortico Posts: 587
    edited February 2019
    Just bumping this to see if anyone can help... thanks!
  • 55LS70
    55LS70 Posts: 184
    FWIW. I replaced the SL 6000 tweeters, in my LS70's, with SL 6001's. The swap worked fine. I think the only difference between the two is that the latter has a humbucker magnet attached to it. Beyond that I've heard of no other tweeters that might serve as a replacement. Good luck with this.
    Decware CSP3 Preamp, RCA 6DJ8, 2 X Rocket 6N1P-EV's, Cary SLA70B Signature V2 Amplifier: 2 X Mullard GZ32's, 2 X RCA/GE 5691's, 4 X Tung-Sol 6550's
    Cambridge Audio 640C V2 CD Player & Dacmagic DAC
    Rega Planar 3: Deep Groove Subplatter, P3 Motor
    upgrade, Dynavector 10x5, JA Michell counterwieght, Cardas tonearm wiring and Mapleshade stand
    Parks Audio Budgie Hybrid Phonostage with BEL 6922 tubes, Polk Audio LS70's
    H.H. Scott 330D AM/FM Tuner with H.H. Scott 335 Multiplex adaptor.
  • jrebisz
    jrebisz Posts: 3
    Hello. I’m trying to find (and purchase) replacement tweeters for my Dads LS 90s.
    It looks like SL6000 or SL6001s will apply.
    Where to buy ?
    Joe Rebisz.
    F1nut Posts: 52,264
    jrebisz wrote: »
    Where to buy ?
    Joe Rebisz.
    eBay is likely your only option.
  • ChrisD06
    ChrisD06 Posts: 929
    jrebisz wrote: »
    Where to buy ?
    Joe Rebisz.
    I was speaking with a guy in the US not too long ago and he mentioned that Polk themselves had the tweeter in stock and he bought two, so maybe give them a call. This was a couple months back but it's worth a shot.
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
  • jrebisz
    jrebisz Posts: 3
    Thank you. I’ll give Polk a try !
  • jrebisz
    jrebisz Posts: 3
    FYI, I called - Polk checked inventory with no result and then said eBay was my best bet.
    F1nut Posts: 52,264
    Like I said
  • ChrisD06
    ChrisD06 Posts: 929
    https://forum.polkaudio.com/discussion/172427/polk-sl6001-and-sl6501-trilaminate-tweeters-whats-the-difference
    As per what Ken said in this thread, the RD6517-1 is a suitable replacement for the SL6001 and 6501... I know you need the SL6000 and SL6500, but perhaps they're interchangeable? Maybe someone could chime in if they know for sure?
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • ChrisD06
    ChrisD06 Posts: 929
    @jrebisz
    Should have tagged you, my bad
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
