RT1000P sub amp circuit board question DESPERATE!
For my old RT1000P, both subs are blown. I can replace a leaking capacitor, but both have one particular resistor (R33) that is burnt up so bad I cannot make out the color bands, so I don't know the value to replace them with. Anyone have the board available and can tell me the color bands on R33 (gold band last) I would be eternally grateful. And I may actually be able to get my subs back online. Thanks!!! Keith
  • womo
    womo Posts: 10
    I've read the RT1000i uses roughly the same board so it might have the same R33 resistor. Worth trying if I can't find anything out about the P board. Thanks
  • WLDock
    WLDock Posts: 3,073
    Check out my March 2015 reply: https://forum.polkaudio.com/discussion/comment/2118495/#Comment_2118495
    It looks to be a 220 Ohm. or whatever they mean by: 220/0.SW
    5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3
  • womo
    womo Posts: 10
    OMG Thanks so much! You saved the day. Yes, schematics say 220, .5W. Maybe they should have put more heat tolerant resistors in, both speakers they're burnt toast. One cap is oozing, but the others look fine. I may replace them anyway while I've got the tools out. They can't be that expensive. Hopefully find them at Fry's here in Atlanta, or Polk directly maybe? I'm encouraged now that it may just be those resistors and cap. Thanks again!
  • womo
    womo Posts: 10
    You think that shape resistor is a special type that I should look for specifically, maybe heat tolerant...?
  • FestYboy
    FestYboy Posts: 3,861
    Shape and size isn't special, it's that way due to the wattage rating. Not sure it's a heat issue, more like it's alway at the wattage limit and something further down the circuit pulled just a little more than usual and "poof". Throw a 1w resistor at it and never have that problem again.
  • womo
    womo Posts: 10
    Well no luck with the first speaker. Replaced the resistor with a new 220, .5W. The caps on this speaker's board look fine (possible they're not I suppose). I did buy four 4700uF 35V (no 25V available, hope that's OK...?)
    So with just the resistor replacement, this speaker powers up ok, with no signs of overheating, etc. but so far no bass output at all, hi-level with jumpers on, or off line-level, auto and OFF, varying the speaker's volume pot, etc...
    I'm a bit confused by the resistor schematic value of 220. The old one is burnt pretty bad, but the first band is pretty clearly brown, not red. I guess possibly replaced improperly by a previous owner, but I don't think so... it looked pristine on the board. Maybe the schematic is in error?
    After letting the speaker run a while (board is powering up) I don't see any signs of overheating so far. Guess my next step would be to replace the two 4700 caps on this board, or maybe the power transistor... But not sure at this point if its really worth hit and miss of every suspicious component on the board. Any thoughts or suggestions how to proceed?
  • WLDock
    WLDock Posts: 3,073
    womo wrote: »
    The resistor looks to be a basic 220 Ohm .5W carbon film resistor
    CFR-1W-220R.jpg&w=400
    Remember that part of the circuit is the hi-level/speaker level input and the resistor is in parallel with the output from your amp/receiver and tied to ground. . So the resistor does see some heat. I would think a metal film or metal oxide type would be used here but maybe not. As far as troubleshooting, it could be a number of things so its hard to say. Much depends on your skill level and how far you want to dive in.
  • womo
    womo Posts: 10
    Yep, that's what the ones I bought look like. Strange that the ones on both L and R boards have a first band brown (see my pic above). I have to think the prior owner must have replaced them at some incorrectly.
  • womo
    womo Posts: 10
    I'm really just looking to get some of the mid-lows from the 6.5" mid-woofers. I have a separate powered sub that I can turn on for some low bass, although frankly I rarely turn it since its just too much for my small living room even at low volume, and the neighbor will bang on the wall (true lol). Is there anyway to just make the RT1000P 3-way, wiring the 6.5" into the speaker's crossover (or installing another crossover maybe). Just seems like my Denon amp would have more than enough power to handle all three drivers, including the 6.5", directly...
  • womo
    womo Posts: 10
    Or maybe i could just install some small basic amp boards in the box to replace what's there and use the speaker's existing crossover sub line level as input for it, to drive the 6.5s. I do really like the sound of these speakers, but wouldn't mind hearing a little more mid lows that i suspect those mid-subs in there can deliver.
    EndersShadow Posts: 17,765
    Power it with a iNuke 1000DSP or similar.
    It’s got onboard EQ so you can play with it however you want.
    Lots of folks have done some similar for MF-15 subs that have bad plate amps (common issue and company went under)
  • womo
    womo Posts: 10
    I'm not sure i understand how this speaker works. If i have it wired up with the jumpers on, no subwoofer line level in, and the switch set to off, does that mean it should be acting as a 3-way passive crossover to all three drivers? Because when I have them hooked up this way tweeters and mids are fine but i get NO output from the woofers. So does this mean the problem is with the crossover boards, not providing low pass? If so where are those boards and how do I even get to them?
  • womo
    womo Posts: 10
    OK from the schematic it appears that the crossover only feeds the tweeter and mid-sub. The sub-woofer comes directly from the plate amp, where the low-pass filtering is happening too I assume. If I'm not mistaken both mid and sub woofers are the same 6.5" 7011 drivers -- the sub just gets some added bass from the enclosure. From Polk: "High Velocity Compression Drive bandpass enclosure joins with Polk's Power Port™ system to deliver spectacular bass response". So I guess I'm SOL as far as wiring the subs in unless I can get the plate amps working again.
  • Redy999
    Redy999 Posts: 1
    edited December 2020
    womo wrote: »
    Hi womo:)
    One year ago I had a similar problem, I wanted to repair everything myself... It was a mistake, seriously, I messed it up. Of course, I'm not an expert. My friend said that it is better to print a new board according to this scheme. Hell, he was right... I spent a lot of time, nerves, and money, but it was all for nothing. After I found one service, I will share it. I didn't want to spend a lot of money, because I also repaired the car but It was not expensive, and these guys are professionals , they know all the pcb basics I think that it is better if you do everything from scratch, but you can also find out what will be more profitable, repair or print a new board.
    I hope it was helpful.
