SherylCrow: The Videos DVD is LPCM
therockman
therockman Posts: 349
edited May 2004 in Music & Movies
I just bought the new DVD of Sheryl Crow's called THE VERY BEST OF, THE VIDEOS. Let me tell you, this disc rocks. The sound quality is awesome, with the soundtrack being an audiophile quality 24 bit/ 48 khz of pure LPCM resolution. I know that a lot of you might wonder what this means. But the audio soundtrack of most DVDs are either dolby digital or DTS, which are both lossy encodeing formats. A lossy encodeing format has to discard (lose) information in order to compress the audio stream into a smaller file. But linear pulse code modulation (LPCM) is a lossless encodeing format, that is in the transfer of the audio stream from analog into digital, there is no loss (hence lossless) of audio information. Consequently, a DVD with a high resolution audio signal (such as this Sheryl Crow with 24 bit/ 48 khz) provides a very smooth, analog sound with an extended top end, thus eliminateing the need for those audible brickwall filters.
And the picture quality of this disc is simply stunning as well. The colors are vibrant, and the blacks and whites are simply stark in riveting contrast. This is a must own disc.
Rocky
Rocky Bennett
Post edited by therockman on
  • PhantomOG
    PhantomOG Posts: 2,409
    edited May 2004
    thanks for the recc.
    i just picked up the DVD-Audio Sheryl Crow album with "My Favorite Mistake" and it sounds awesome.
    looks like I should pick up this videos dvd as well.
  • danger boy
    danger boy Posts: 15,722
    edited May 2004
    thanks guys. i'll have to make this a must buy. I love Sheryl Crow. she's an awesome rocker. I have the DVD-audio The Globe Sessions. It's one of my fave discs of all time.
    PolkFest 2012, who's going>?
  • mantis
    mantis Posts: 17,563
    edited May 2004
    voice body face of an angel
    Dan
  • danger boy
    edited May 2004
    hey how do you know it's 24bit? it says AC3 surround 2.0 which in my player plays it in pro logic.
    sounds seems good. but it's about the same i've heard on most other "videos, greatest hits collections". either way.. i love Sheryl Crow. we need more female rockers like her.
  • therockman
    edited May 2004
    That is why I started this thread, the package does indeed say that the disc is a dolby digital AC-3. But when you play the disc (at least my copy), there is no audio set-up menu, the only audio soundtrack is an LPCM soundtrack. The way that I know that this disc is a 24 bit/ 48 khz is that I have access to that information in my video display of the DAC section of my DVD player. I simply hit display, scroll through a few modes and the native resolution of the disc is displayed in the video monitor.
    Because this disc is a high resolution audio disc, I am by-passing all DSP circuitry (including pro-logic) and I am playing this disc straight from the DAC through the analog circuits of my pre/pro. This straight analog signal is the cleanest way to listen to any high-resolution digital source, it simply by-passes all un-needed DSP circuitry and gives an un-processed sound.
    Rocky
    Rocky Bennett
  • danger boy
    edited May 2004
    ohhhh my bad. sorry i didn't know you were bypassing all DSP modes and going all analog. so then your player does the decoding instead of your receiver? or no decoding needed?
    i'll have to try that out as well. using the analog only inputs.
  • therockman
    edited May 2004
    Exactly, I am playing this disc the same way that a person would play an SACD or a DVD-A. The internal DAC circuit is in the player, then I am using a set of RCA style analog jacks to pass the analog signal to my receiver at the pre/pro point, a point much further down the line than any DSP circuitry. This pure audio signal is then simply amplified and the resulting music is a holographic sound of the purest quality. I have checked many other DVDs and this is the only one that I own that has this high resolution audio soundtrack.
    Rocky
    Rocky Bennett
