Woodbourne questions...push twice to power on?
Hi all...just got myself a used Woodbourne. Love the sound but a couple things bug me. The auto power off feature...no way to override that huh? Really bums me out as I have it connected to Alexa. Also, I have no remote, so when I power it back on...I have to push and hold the power button, it comes on...powers off...then, I push and hold power again...stays on. Is this normal?
    EndersShadow Posts: 17,723
  • MrBuhl
    MrBuhl Posts: 2,419
    For mine its push once on the power button, but it takes a second or so to power up.
    So when I first purchased I had the same trouble, push and hold seemed to turn it on and off or on and switch off BT to wifi (I use it in BT).
    Frustrating till i realized a quick on push followed by a little patience brought everything up exactly as normal. Your mileage may vary.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
