Why has neutrik nl4 not taken over home audio
Arguably a superior connection to even the best binding post and costs fractions, what's the rub?
It's just not sexy enough
Funny I was wondering the same thing while I was putting together my nuetrik-dreadnaught cables. It seems secure, foolproof, and free from contaminants once it clicks into place.
It's honestly just a better connection, period. But binding post as stated look higher end, I guess. Just seems foolish, same thing as using hdmi versus HD base t
Ohh well!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Yup...... I’ve debated making some of my own cables using Kimber 8TC. Banana at one end..... Neutrick at speaker since my next ones will be DIY based.
I am going with Nuterick for my surrounds for sure, at least at the speaker end lol..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Thanks to Trey, my 2.3TL's have 2 beautiful interconnect cables that connect to the terminal plates and dreadnaught case via NL4 connectors.
Very good question!Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Can’t take bare wire without requiring another purchase.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
If a company started doing this, they would severely limit their market share.
It is not the "standard" that is recognized across the industry. Most folks across the globe cannot mod the connections them self, they do not know anyone (nor would they want to ship) who could do the mod and the selections of "Upgrading" a cable right now stand next to zero.
While I have these connectors in my rig, if I were to upgrade.....let's say my speaker cables.....what would my choices be?
I rest my case.
You are just a negative Nancy
They should start including them in speakers now and offering the option and in twenty years when this hobby is officially dead it will be the standard!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Hey, I'm all for it. They *should* be the standard IMO.
I have not had a loose connection since these became the "standard" in my rig!
Not sure in this case, "If you build it, they will come", applies here though. I'm afraid we will be stuck with Nanner's and wire for all time.
I would add that the Neutrik's are much larger (~ 2X) than a typical binding post or IC interface. This would force the back panels to grow, the layout of the back panels to grow, add more material, and thus cost more. The size of the component chassis may even get larger as a result.
Any component that incorporates them into their product would have to offer both options, much like the balanced and unbalanced IC's some companies offer on the back panels.
I agree that they are far superior, but with manufacturers trying to keep costs down, and the industry standard being otherwise, it may take a while for it to be more common. Just my thoughts.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
My non powered dj speakers have used this connection for years.
On a side note, for my powered dj speakers, they use powercon. For home audio, neither are common but in pro audio, its way more common. -
While they're at it, Get rid of F-connectors and only use BNC
If I were "King of the World" I would fix it.
I'd probably last about a week before I got shot.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
If you have ever had a Chinese speakon knockoff get locked into an amp or speaker you might think different. Neutrik brand only in my pro rigs.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
It'll never happen, far too much home audio gear floating around in the world with binding posts on them already.Political Correctness'.........defined
