Record storage
  • machone
    machone Posts: 1,566
    I found these at Target.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • dromunds
    dromunds Posts: 10,140
    Where were they at Target?
    SCompRacer Posts: 9,123
    edited January 2019
    Manticore wrote: »
    Very nice indeed and a great idea. Would you happen to have dimensions for this build? I already purchased the ply wood for original post but, i like this better.
    Thanks for the kind words! I have a basic diagram with dimensions. I made sure there was enough room between top and bottom to comfortably get records out of the lower bin. The sides and fronts are Oak.
    I used a router to slot all joints and a Kreg pocket-hole jig tool for glue and screw construction. It is plenty sturdy. It doesn't flex at when rolling it around loaded. I didn't bother filling the pocket holes since they are not visible. The pic below is of the back side which is usually against a wall.
  • Manticore
    Manticore Posts: 408
    Thanks for the diagram. I will see if i can do it with the one piece of plywood that i purchased. Wood working is not my forte. I don't own a router or the other tool shown.
    I will do my best...photos to follow as soon as i get my butt moving.
    Denon AVR X4200W
    Parasound A23 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    Vincent PHO 701 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk SDA 1C's modded
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
  • verb
    verb Posts: 10,176
    Love the pocket hole jig @SCompRacer ! On my list of tools to get! :smile:
    Manticore wrote: »
    You can look at renting a router. Places like Home Depot have tool rental. You would need an edge attachment to keep the router on path. Them things will get away from you free hand!
    If not, using more screws would give you more strength.
    verb wrote: »
    It's a great tool! I used it to build our L shaped bar too. You can get plugs for the pocket holes too. Glue and knock them in, sand down.
  • CoolJazz
    CoolJazz Posts: 572
    I did a build based on those plans posted at AK. Made this one for a friend.
    I pretty much used the plans and used modest ply. Added wheels to make it movable.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • SCompRacer wrote: »
    Manticore wrote: »
    Good information to know. I asked the boss and she like the first plan better so i have it all cut up and ready to be sanded and put on a finish. Hopefully will be finishing up soon.
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
  • muncybob
    muncybob Posts: 3,267
    Jazz, you have a lucky friend!
    Yep, my name really is Bob.
  • jonicont
    jonicont Posts: 281
    I have a storage closet. Stacked modules. Lifted the design from Mapleshade.9co8i9csdtgp.jpg
    Custom--my design--from a friend who used to build real roadcases llj4zwcove5a.jpgg6tgqbc6glr9.jpg
    DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
  • Lets keep the laughter to a minimum please. Here is my finished attempt at building a record storage box. Please remember i know absolutely nothing about woodworking.
    Had i known more i would have not had the screws showing in the final build. I put 3 coats of poly on making sure i sanded lightly between coats. I actually thought the poly would have been thicker than it actually turned out. Maybe i needed 5 coats or more?? I did add some wheels purchased from the depot. I do like the idea of being able to roll it around if needed.
    I must say there is something really nice, satisfying about woodworking. Taking a piece of wood and converting it to something beautiful & useful.
    I found some LED lighting for the bottom compartment. It has a remote, motion detection and four light colors but, the white light is perfect for seeing those albums on the bottom. As for the top i am just using some old desk light i had floating around till i find something a little more attractive.
    Thanks for the original post and all those that chimed in with ideas and plans and finished products. I really liked the 2 piece unit but, when the boss puts her foot down!
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
  • motorstereo
    motorstereo Posts: 2,368
    Here's my record storage for the past 10 years. It was a discarded fridge that fit perfectly into a former window opening. The window opening is on the backside of the building where it's not visible and I never looked out it anyways. I saw the fridge as an insulated, secure and waterproof box to start with. One afternoon of framing, then added a couple shelves and an led light and I have lighted record storage that doesn't take up floor space inside the listening room. Certainly not something you'll see on an episode of Cribs but it works for me.
  • verb
    verb Posts: 10,176
    Manticore wrote: »
    Looking good! :smile:
  • dromunds
    Yeah, looking good. You gotta work on that "when the boss puts her foot down" stuff tho. :D
    Clipdat Posts: 13,100
    Manticore wrote: »
    I'm not laughing at all, that looks great! Nice job man.
    EndersShadow Posts: 17,722
    NOICE!
    edited February 2019
    Manticore wrote: »
    You done good! The rule for visible fasteners is placement, and your upper and lower screw placement match. I bet it wasn't by accident.
    You can tell if poly stops absorbing into the wood. Looks like a uniform sheen under the lights.
    Love the lower LED!
    My little buddy Jasper helps me pick, he has better eyesight for the lower section.
  • Willow
    Willow Posts: 11,258
    Clipdat wrote: »
    Manticore wrote: »
    I would agree. I don't think I could build something like that
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Manticore wrote: »
    I think you did a very good job, nice selection of LP's it's holding!
  • muncybob
    I see more albums that need a home...time to build another! If you are like me, I build one wood thingy(called the prototype model)and then get ideas to improve it and build another that usually looks even nicer.
  • Thanks everyone for the flowers! I tried my best and for the most part i am very happy with the build and having WAF on this project.
    dromunds wrote: »
    Happy wife happy life!! Its a work in progress or she may say i'm i work in progress.
    I'm just grateful she lets me wear pants every now and then! ;)
    @SCompRacer
    "You done good! The rule for visible fasteners is placement, and your upper and lower screw placement match. I bet it wasn't by accident."
    That's my OCD kicking in. It had to look uniform.
    My buddy told me to set up a jig and... I said the only jig i know of is the Irish jig.
    I don't have a table saw and the blade on my circular saw was old and didn't give me a clean cut ( even when taping the cut line) so i stopped and bought a new blade. Partial damage already done. Glad i had a finishing sander to help remove some product from the off cuts.
    The rest was easy peasy. I pre-drilled holes for the lag bolts to put on the wheel assembly. There was absolutely no splitting of wood at all and they are solidly attached to the bottom. Although i will be careful rolling it when needed. Records do weigh a bit and wheels on carpet can't be good.
    Overall a very satisfying project and i would not hesitate to attempt this again.
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
