Carver TFM's with RTi12's?
imsjry
What's the feeling here of paring Carver amps with the RTi's? I keep reading to go with B&K or Parasound but the price of the used Carvers are more in range ($300-400).
Thanks for any input!
The Carvers will need a recap if they have not already been done. Everything below the TFM 45 is not very well regarded. I might take a look at the M-500 as well. The meters on that one are rather nice to watch, and it sounds really good to boot.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Agree with what John said and M500t might be a little warmer. B7K also makes a solid amp and usually can find them in the 300-400 range. Any of the 3 you mentioned would be decent.
The Carver M-500t would be a nice pairing with those speakers. Second choice would be a M4.0t. Both will pair nicely.
Now, John, you forgot about the TFM15cb. That one had a killer sound signature. Not much umph but really smooth sounding.
Never heard one Tom, but that thing is almost a flea-powered amp compared to the rest.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Can't dispute that.
I like the early US made Carver amps. My first true stereo system was the M500t and Polk SDA2b's. If you can find a low hour amp that was not abused, chances are it will still sound good. 1.0, 1.5 and 4.0's are still very capable amps. I have not heard anything in the TFM line but they can't be all bad.Gustard X26 Pro DAC
I really liked my Carver TFM 45 and TFM 55, but I never paired them with RTi's. Great amps and run cool as a cucumber.Things work out best for those who make the best of the way things work out.-John Wooden
TFM45 and M4.0t are the same amp in different colors from what I always understood. M4.0t is the earliest of the two.
Still both will need recapped and maybe other work.
Correct, the “M” series came before the “TFM” series.
M 4.0t, TFM 42, TFM 45 are all the same basic amp, with minor variations in the damping circuit. FWIW, the 4.0t is the preferred model, as it seems to have less of an issue with turn on/off thump/squeal. There are about 12 service bullitins that need to be performed on a 45, where the 4.0 has 3. Recap cost is the same, and both models will be in need.“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
― Aleksandr Solzhenitsyn -
You do NOT want to pair these speakers with the M1.0t. The end result will be very bad. Bright, shrill, scrape the chalkboard with fingernails type of bad. Definetely not a good pairing right there.
Agreed. I had one of those and it was not a good experience. BTW, does anyone know where the OP went?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I don't.
I would use the M1.0t for an external sub amp. For that, it's great.
nooshinjohn wrote: »BTW, does anyone know where the OP went?
Crazy?Gustard X26 Pro DAC
I have a TFM25 with an old Nakamichi PA-1 (a 5 channel home theater pre amp) running my SDA CRS+speakers but I'm not a huge fan of the sound. It's thin and whiny. There's a lot of options for what to fix/replace, but until I read this thread, I didn't think the amp could be one of the problems. I'm planning on doing the TL upgrade on the speakers when I have time and money. How much do you think it would cost to recap the TFM25 and is it worth it? I use this system mostly to play around with equipment without spending tons of money so I'm not looking to spend a lot.2 Channel: Atohm GT-1 speakers, Atoll IN400 integrated amp, PS Audio DirectStream DAC, PS Audio NuWave Phono Converter, Pro-Ject Debut Carbon Esprit SB with Ortofon Bronze cartridge, SotM sMS-200 ultra streamer, SotM sPS-500 power supply, and homemade infinite baffle subwoofer with two Fi Audio IB318 drivers.
HT: All Polk: SDA 2.3tl fronts, CSiA6 center, 500-LS ceiling, RT/FX, RTi8, Monitor 4 rears, plus Yamaha CX-a5100 AV Preamplifier/Processor, Yamaha MX-a5000 11.1 channel amplifier, and Sony XBR55-AE1 OLED TV. -
There is a chill in the air, and it ain't coming from old man winter....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Agreed on Roland. When i had a c-19 and sunfire sig II, both went to him.
Looks like we are talking to the wind anyway....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Thanks for the info. I’m intrigued. I’ll see if I have money for it after paying for the dreadnaught. I suspect my weak link is the preamp more than the amp but I’d like to hear the TFM fixed up.2 Channel: Atohm GT-1 speakers, Atoll IN400 integrated amp, PS Audio DirectStream DAC, PS Audio NuWave Phono Converter, Pro-Ject Debut Carbon Esprit SB with Ortofon Bronze cartridge, SotM sMS-200 ultra streamer, SotM sPS-500 power supply, and homemade infinite baffle subwoofer with two Fi Audio IB318 drivers.
I suspect my weak link is the preamp...
Easy to spend a ton of money and time on amps with little improvement if your upstream is side is subpar. Don't ask me how I know...Gustard X26 Pro DAC
https://www.audiogon.com/listings/lis9a8ch-classe-cp-35-with-phono-stage-solid-state
This will significantly up the preamp portion of your setup for little cash, but it is two channel only. not sure if it has HT bypass.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Wow, that's a great price on that Classe pre. Don't think I ever seen one that cheap.HT SYSTEM-
lsi 9's -
I hope the OP jumped on that because it is G. O. N. E. gone!Gustard X26 Pro DAC
Thanks all! Missed that offering unfortunately. I ended up bidding on a B&K 202+. Fingers crossed!
