Carver TFM's with RTi12's?
What's the feeling here of paring Carver amps with the RTi's? I keep reading to go with B&K or Parasound but the price of the used Carvers are more in range ($300-400).
Thanks for any input!
    nooshinjohn Posts: 25,100
    The Carvers will need a recap if they have not already been done. Everything below the TFM 45 is not very well regarded. I might take a look at the M-500 as well. The meters on that one are rather nice to watch, and it sounds really good to boot.
  • erniejade
    erniejade Posts: 6,315
    Agree with what John said and M500t might be a little warmer. B7K also makes a solid amp and usually can find them in the 300-400 range. Any of the 3 you mentioned would be decent.
    treitz3 Posts: 18,334
    The Carver M-500t would be a nice pairing with those speakers. Second choice would be a M4.0t. Both will pair nicely.
    Now, John, you forgot about the TFM15cb. That one had a killer sound signature. Not much umph but really smooth sounding.
    Never heard one Tom, but that thing is almost a flea-powered amp compared to the rest.
    Can't dispute that.
    audioluvr Posts: 5,437
    I like the early US made Carver amps. My first true stereo system was the M500t and Polk SDA2b's. If you can find a low hour amp that was not abused, chances are it will still sound good. 1.0, 1.5 and 4.0's are still very capable amps. I have not heard anything in the TFM line but they can't be all bad.
  • PSOVLSK
    PSOVLSK Posts: 5,059
    I really liked my Carver TFM 45 and TFM 55, but I never paired them with RTi's. Great amps and run cool as a cucumber.
    pitdogg2 Posts: 24,579
    TFM45 and M4.0t are the same amp in different colors from what I always understood. M4.0t is the earliest of the two.
    Still both will need recapped and maybe other work.
  • daddyjt
    daddyjt Posts: 2,326
    Correct, the “M” series came before the “TFM” series.
    M 4.0t, TFM 42, TFM 45 are all the same basic amp, with minor variations in the damping circuit. FWIW, the 4.0t is the preferred model, as it seems to have less of an issue with turn on/off thump/squeal. There are about 12 service bullitins that need to be performed on a 45, where the 4.0 has 3. Recap cost is the same, and both models will be in need.
    "Conservative Libertarians love the country, progressive leftists love the government." - Andrew Wilkow
    ― Aleksandr Solzhenitsyn
    You do NOT want to pair these speakers with the M1.0t. The end result will be very bad. Bright, shrill, scrape the chalkboard with fingernails type of bad. Definetely not a good pairing right there.
    Agreed. I had one of those and it was not a good experience. BTW, does anyone know where the OP went?
    I don't.
    I would use the M1.0t for an external sub amp. For that, it's great.
    Crazy?
    Careful my man
  • BC6
    BC6 Posts: 109
    I have a TFM25 with an old Nakamichi PA-1 (a 5 channel home theater pre amp) running my SDA CRS+speakers but I'm not a huge fan of the sound. It's thin and whiny. There's a lot of options for what to fix/replace, but until I read this thread, I didn't think the amp could be one of the problems. I'm planning on doing the TL upgrade on the speakers when I have time and money. How much do you think it would cost to recap the TFM25 and is it worth it? I use this system mostly to play around with equipment without spending tons of money so I'm not looking to spend a lot.
    2 Channel: Atohm GT-1 speakers, Atoll IN400 integrated amp, PS Audio DirectStream DAC, PS Audio NuWave Phono Converter, Pro-Ject Debut Carbon Esprit SB with Ortofon Bronze cartridge, SotM sMS-200 ultra streamer, SotM sPS-500 power supply, and homemade infinite baffle subwoofer with two Fi Audio IB318 drivers.
    HT: All Polk: SDA 2.3tl fronts, CSiA6 center, 500-LS ceiling, RT/FX, RTi8, Monitor 4 rears, plus Yamaha CX-a5100 AV Preamplifier/Processor, Yamaha MX-a5000 11.1 channel amplifier, and Sony XBR55-AE1 OLED TV.
    edited January 2019
    Careful my man
    Sorry. Forgot we are being watched.
    audioluvr wrote: »
    Careful my man
    There is a chill in the air, and it ain't coming from old man winter....
    BC6 wrote: »
    Contact Roland at
    http://carveraudiorepair.com/hitechaudioltd/workmod.html
    He has done a lot if work for my and is very very good at the Carver stuff. I have both the TFM25 and TFM45 both completely rebuilt and with some film caps in good places. I never found my TFM25 to be as you described. BOTH did sound much better after Roland worked his magic. There has always been a long wait time in the past but worth IMO
  • erniejade
    Agreed on Roland. When i had a c-19 and sunfire sig II, both went to him.
    edited January 2019
    BC6 wrote: »
    Contact Roland at
    He has done a lot if work for me and is very very good at the Carver stuff. I have both the TFM25 and TFM45 both completely rebuilt and with some film caps in good places. I never found my TFM25 to be as you described. BOTH did sound much better after Roland worked his magic. There has always been a long wait time in the past but worth IMO
    Fixed it !!
    Junk vanilla said i had 60sec. then said i needed vanilla permission to edit......
    Looks like we are talking to the wind anyway....
  • BC6
    BC6 Posts: 109
    Thanks for the info. I’m intrigued. I’ll see if I have money for it after paying for the dreadnaught. I suspect my weak link is the preamp more than the amp but I’d like to hear the TFM fixed up.
    BC6 wrote: »
    I suspect my weak link is the preamp...
    Easy to spend a ton of money and time on amps with little improvement if your upstream is side is subpar. Don't ask me how I know...
    https://www.audiogon.com/listings/lis9a8ch-classe-cp-35-with-phono-stage-solid-state
    This will significantly up the preamp portion of your setup for little cash, but it is two channel only. not sure if it has HT bypass.
    tonyb Posts: 32,906
    Wow, that's a great price on that Classe pre. Don't think I ever seen one that cheap.
    I hope the OP jumped on that because it is G. O. N. E. gone!
  • imsjry
    imsjry Posts: 120
    Thanks all! Missed that offering unfortunately. I ended up bidding on a B&K 202+. Fingers crossed!
