how to order replacement driver
i need to buy a replacement woofer for a t-15 that i use as a surround speaker. called the number three times, waiting over twenty minutes each time and nobody picked up. how can i reach these people to purchase a new driver?
    F1nut Posts: 52,156
    You have to call to order, there is no other way.
    That said, you can buy a brand new pair for $60.00 at Best Buy, which is likely cheaper than buying a new driver.
    VR3 Posts: 29,630
    Called Polk the other day, on hold over 45 minutes, finally decided to try the call back function, they called me thirty minutes later...
  • erniejade
    erniejade Posts: 6,321
    When I ordered the RDO, I also used the call back function.
  • mmorse
    mmorse Posts: 2
    i tried that too with no luck. now when you call that function is not even offered. the message simply says to call back later. what gives with this company?
    F1nut Posts: 52,156
    mmorse wrote: »
    Not that you will see this until I'm let out of polk prison, which I'm in for a completely unjustified reason.
    If I told you what gives they'd never let me out of polk prison.
