Magnifying Glass Lamp or Glasses for Close Soldering?
msg
msg Posts: 10,477
edited December 2018 in DIY, Mods & Tweaks
Hey, any of you guys know a of a good place and specific product for magnifying close up soldering work?
I've seen those magnifying/lamp combos that are swing arm mounted, and also some magnifying glasses that you'd wear.
Features to look for, useful magnification level, preferred brands, products, etc.?
I checked out some glasses at Harbor Freight, but not quite the quality I'm looking for.
Also seems like 3x magnification wouldn't be the upper limit I'd like, but would be a useful option.
  • machone
    machone Posts: 1,566
    I have both. Glasses are better. The lamp gets in the way. I use an Optivisor.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    msg Posts: 10,477
    Great, thanks!
    Which lenses/magnification do you use, and what kind of tasks do you use it for?
    Do you wear it with eyeglasses?
  • machone
    Not sure about the lenses power and I would recommend glasses if you normally wear them.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    mhardy6647 Posts: 35,253
    Can you buy those things like my dentist uses on the open market? That seems like it would be ideal for soldering SMDs, e.g.
  • motorstereo
    motorstereo Posts: 2,374
    This is what I use. It has interchangeable lenses and right now I'm using a +5 for times like today when my +1.50 reading glasses just aren't enough
    msg Posts: 10,477
    Which brand/source is that one, please?
  • motorstereo
    ^^^^^I honestly don't remember as I've had it for several years. I do know that Harbor Freight sells ones that look quite similar.
    edit; I just checked and the only marking on them are Donegan Optical Co. made in USA. They must be old to have been made here in the states.
    msg Posts: 10,477
    That's a second for Donegan. Nice, thanks!
  • machone
    It looks like Donegan makes Optivisor.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • motorstereo
    machone wrote: »
    Yes they do and it looks like they run about $40
    msg Posts: 10,477
    I decided to give that Yoctosun one a shot, and it arrived today.
    Not bad for $16. The lenses are surprisingly clear. Used them to change a watch battery earlier just for fun. Pretty comfortable to wear.
    Not sure how this is going to work out for soldering though since you have to get your face kind of close up to the work to focus. I imagine I'll be running a small fan to evac the fumes/smoke.
    https://www.amazon.com/YOCTOSUN-Magnifier-Professional-Jewelers-Interchangeable/dp/B01H8808H6
    I'll report back if they end up totally sucking.
    txcoastal1 Posts: 13,519
    Pics wearing them or it never happened B)
  • sbb2112
    sbb2112 Posts: 134
    msg wrote: »
    How did you like these? I have 3 of the optivisors and the band tightening knob on 2 is not staying tight anymore so looking for better
    Main System
    Marantz AV8802A PrePro
    Marantz MM7025 Amp rear surrounds
    McIntosh MC7205 Amp center, ceiling and mid surrounds
    McIntosh MC300 Amp front mains
    Oppo 203 Bluray
    Polk SDA-SRS with VR3 monastery crossovers
    Polk FX1000 Mid surrounds
    Klipsch RP-440C Center channel
    Klipsch RP-15M Rear surrounds
    SVS prime elevation ceiling surrounds
    Rythmik F15HP sub
    Samsung 8500 curved screen 65" LED 4K
    Mac Mini Server
    Office System
    Musical Fidelity M6s dac/preamp
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
    msg Posts: 10,477
    These did not end up sucking, I'm happy to report. I've gotten quite a bit of use out of them already, and even for some unexpected stuff, like fixing a user-mangled DVI socket on a video card
    Works great so far for little projects here and there, but I've not had a chance to solder with it. The only thing I've noticed is that I end up getting my face really close to the work while wearing these. Need to take a measurement, but I'd say around 8" - 12" away with the max mag glass in place. Not sure how well that's going to work out. Not feeling particularly enthused at the thought of flux and solder spatter, and I'll definitely need a fume fan.
    Pretty comfortable, though, and the LED's a nice touch. I typically wear a headlamp while doing this sort of work, and haven't needed it.
    Definitely worth the $16.
    I've also picked up soooo many chicks while wearing these. Way more than @Hermitism, except when he gets new boots.
    Where's my pic? :p
  • Hermitism
    Hermitism Posts: 4,338
    I have old school jeweler's glasses that look like something a mad professor would wear and you have to get really close, also. It's great for getting splinters out of a finger. It has another lens that folds over in front to double the magnification. The chicks dig it. No light unless I duct tape a flashlight to my head.
  • sbb2112
    sbb2112 Posts: 134
    Why has F1's avatar been hijacked? Banned?
    Main System
    Oppo 203 Bluray
    Rythmik F15HP sub
    Mac Mini Server
    Office System
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
    msg Posts: 10,477
    txcoastal1 wrote: »
    Where's my pic? :p
    I'm doing my hair.
    edited January 2019
    msg wrote: »
    txcoastal1 wrote: »
    Where's my pic? :p
    I'm doing my hair.
    Does it look bigger, asking if I need to get a pair for the wife
  • reverb
    reverb Posts: 67
    +1 for the OptiVisor. Tried the lamp as well but it always seems to be where I don't need it to be.
