PSW 505 Fuse: Fast or Slow Acting?
An incompetent electrician sent a surge through one panel of my house. Most important stuff was on surge protectors but not the sub. The fuse is not merely blown, it exploded. I can't tell if the replacement should be fast acting or delay acting, can someone advise?
Best Answers
    pitdogg2 Posts: 27,486
    edited December 2018 Answer ✓
    JohnBF wrote: »
    Thanks, I have that spec, but Amazon shows it as available in both fast and slow blow versions. Which should it be?
    Are you referring to Amazon having both fast and slow blow and you're still confused?
    Most fuses are made in both fast and slow blow. In your case you need fast blow. So that is what you need to replace it with.
  • JohnBF
    JohnBF Posts: 7
    Answer ✓
    Are you referring to Amazon having both fast and slow blow and you're still confused? ... In your case you need fast blow.
    Exactly what I was confused by, thank you PittDog2.
Answers
