Need advices on LSIM setup
potvin103
Hey,
Recently bought the LSIM 707 pair and the 706c + a pair of 703.
Also bought Sony STRDN1080 7.2 Channel Atmos Network AV Receiver. Will it be enough? I've read that we need an external amp to power up those speakers. Is that absolutely needed? Also, would you recommend adding a sub? I live in a condo so I won't really crank that up I just want the most quality possible.
If the receiver above is not good enough, could you recommend one for this setup? Budget is around 1k + 1k for the amp if needed (xpa 3).
Room is 13 w x 18 h x 18 l (open living room) and looking to play music + ps4
Thank you so much!
Thank you so much!
In a word, no that AVR isn't enough. At a quick glance its an entry level unit @ $400 bucks, only weighs 21# and doesn't appear to have pre outs to add an external amp even if you wanted to. Is it too late to return it and go with something better suited for your needs?
ken brydson wrote: »In a word, no that AVR isn't enough. At a quick glance its an entry level unit @ $400 bucks, only weighs 21# and doesn't appear to have pre outs to add an external amp even if you wanted to. Is it too late to return it and go with something better suited for your needs?
No it's not too late at all. Would Onkyo TX-RZ820 7.2 Channel Network AV Receiver be a better choice? If not, which one would you recommend in the 1-1.5k budget? -
Stay away from Onkyo.
Cool! But it looks like this specific one is not really available here. I can get the AVR-X4500H, is it the same thing? Or the AVRX3500H? Both are the same price here. -
Welcome to Club Polk!
You have purchased Polk's top of the line speaker set, you would do much better to up your game with your receiver or even switch to a prepro.
Most around here prefer Marantz, or Denon receivers. Look for ones that have everything the Sony has, and then make sure it has preouts to add a separate amp. Your Sony does not have these.
Something along these lines will help get you there.
https://www.amazon.com/Denon-AVRX4400H-Channel-Network-Receiver/dp/B072Z6VT1C/ref=sr_1_5?s=electronics&ie=UTF8&qid=1546027696&sr=1-5&keywords=denon
https://www.amazon.com/Marantz-SR5012-Channel-Surround-Receiver/dp/B072ZJ9SRM/ref=sr_1_4?s=electronics&ie=UTF8&qid=1546027832&sr=1-4&keywords=marantz+receiver
Shop around for the best price.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
That’s the newest version. The 4xxx is a little bit more robust version compared to the 3xxx series. -
Have you considered used? Are you after ATMOS, Audyssey DSX or not? Could find a pre/pro and amp for that money.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3 -
Thank you so much for your answers!! I'll go with the AVR-X4500H since everyone recommend the 4400 but it's not available here. Hopefully their newest version will work!Have you considered used? Are you after ATMOS, Audyssey DSX or not? Could find a pre/pro and amp for that money.
I don't mind used! And I have no idea what those things are.
Would the XPA-3 be a good add? -
It will get you up and running with your front 3 channels operating to their full potential. Only you can decide if you like the sound signature.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
