TCL 55R617 with polk audio magnifi one soundbar? how can I get volume working?
my tv (TCL 55R6517) uses an RF remote. my understanding is that I cannot teach the soundbar the volume commands since it is not IR?
is there any option to allow me to use the tv's remote volume to control the soundbar volume?
  • rpf65
    rpf65 Posts: 2,127
    Some TVs you have to tell it you’re using external speakers, others you have to use the ARC enabled HDMI port.
  • redi6
    redi6 Posts: 2
    rpf65 wrote: »
    Ok thanks. In my case the soundbar only has optical in from the TV. So no HDMI to the soundbar. I'll check TV setting though. Haven't set anything up yet.
  • WLDock
    WLDock Posts: 3,073
    Interesting, I have a family member that has a Panasonic TV that I couldn't get to work when I last tried. The TV has an ARC port but still no dice. I'll have try try a few other things when I get back in town next week.
  • rpf65
    rpf65 Posts: 2,127
    My Panasonic you have to go into the menu and tell the TV that you’re going to use external speakers.
