Command Bar / Echo Dot Solid Red Ring
I keep having to unplug the Command Bar from the wall to get the built in Echo Dot to reboot as so often when I say "Alexa" to give a command, the light ring turns solid red and Alexa says "I'm sorry, I'm having trouble understanding right now. Please try again later." This does not happen on any other Alexa device I have in my house except for the Echo Dot built into the Command Bar. I have spoken to Amazon's Echo Dot department multiple times about it, but it seems it may be a problem on Polk Audio's side. Please advise.
Answers
    F1nut Posts: 52,207
    Who's Alexa and what's an Echo Dot?
  • ibims
    ibims Posts: 3
    dude. you have the same poblem like me. the thing is that the command bar looses the wlan because the polk connect app deletes our profile. i tried with new profile now 3 times. every second day the app deletes the profile and alexa has no internet again. If you look at my post you can see no one is helping us but when you check the reviews for the connect app a lot of users have the problem. add me on skype if you like: acelimper
  • [Deleted User]
    Hello,
    I'm sorry there's a problem, let me refer this to a friend in Polk engineering who is familiar with the Command Bar.
  • [Deleted User]
    His response:
    "This is a known issue and only seems to happen with certain WiFi networks. The fix is already in place and a firmware update will be released in 1-2 weeks."
  • ibims
    ibims Posts: 3
    edited December 2018
    Certain networks. This is funny. I have a Fritz Box :D ok when they work on it its ok for me but if not its really messed up for me and lot of others i guess. hope they can fix it ! thank you for youre answer my friend.
  • ScottSalo
    I have a Command Bar with a red ring. It occurred once before. But, it was corrected mysteriously with an array of trial and error guesswork. Subsequently unable to know what the fix was. It is now Sept 2021, three years past the last post. So, I am guessing the firmware fix didn't take. Is there a reset option available? I have only had this setup for a short while. I am really bothered by that, in addition to the initial concern. Who do I contact?
  • SeleniumFalcon
    I recommend sending an email to: Kim.Jasper@soundunited.com for assistance.
