Mix and match
Hi, I have a 5.1 pioneer home theatre system. Unfortunately, don't have place for rear speakers. But have 2 Polk ceiling speakers at the rear end pre-installed. Any thoughts if front 3.1 and rear ceiling speakers combination work in terms of sorround sound? Newbie to the world of sound.
  • mrloren
    mrloren Posts: 2,474
    yes the in-ceiling will work just fine
    Tony M Posts: 11,865
    edited December 2018
    My rear speakers are mounted in the rear ceiling corners of my room and sound great. Polk M3's. B)
    Ceiling speaker placement, if behind you..( how far are yours behind you? )will serve the same purpose. See if they have directional tweeters in them.
  • afterburnt
    afterburnt Posts: 7,892
    HT rears should be fine with any decent speakers. Now 5.1 SACD the crowd may differ.
  • BlueFox
    BlueFox Posts: 15,250
    More than likely, it will be okay. I suspect that stand alone speakers in the rear will be better, but it depends on many factors. Do it and find out.
