Do I need to replace the main drivers in my RT bookshelf speakers
I recently purchased a set of secondhand RT3 bookshelf speakers.
At Low volume they sound very muddy and are very hard to listen to ,they sound better with more volume. Do I need to replace the main drives ?
Cheers
Craig
Answers
    F1nut Posts: 52,149
    The problem is likely the tweeters and/or the crossovers. When the tweeter isn't playing the speaker will sound very muddy.
  • Thanks for that, how do I check the crossovers
  • I have put my ear up to the tweeter and they are working ,sometimes it sounds muddy and sometimes it's not as bad
  • rooftop59
    rooftop59 Posts: 8,120
    Perhaps crossover or a bad connection. I had a pair of those where the internal wires came loose during shipping, so I would open them up and look at the crossover and make sure the connections are all secure.
    Game Room 5.1.4:
    Bedroom 2.1
