New Polk Magnifix Max - HDMI issues
nightgarages14
Maybe someone can help here. I've just setup my Magnifi Max system. I've connected an Apple TV 4k and a cable box via HDMI into the soundbar, and then I ran an HDMI cable from the soundbar (ARC) to the TV's HDMI ARC port. I'm able to watch something using this method for a few minutes....and then the TV will go black, and then display "NO SIGNAL - HDMI 3) The ARC port is HDMI three. Funny thing is I can still here the sound. I've switched out HDMI cables. I also updated firmware for both the TV and the soundbar. I also enabled the CEC on the TV. No avail. Any suggestions? It'd be a shame to have a brand new soundbar with all this capability only to run optical.
Yea, im in the same boat with my Xbox one X, i wanted to use the 4k pass-thru on the sound bar but if thats not going to work ill just return it and go back to using optical on my old sound bar.
Same issue as described above
