Insulating garage door
This may not be the best place to ask, but I need to insulate my garage door to keep the dogs warm (this year we gotta put em in the garage all winter).
This isn't audio related at all, but I figured a few folks may have done this so why not ask.
Is it best to purchase a kit, or is it better to buy all the stuff yourself? Any kit you recommend over another, etc.....
«13
  • verb
    verb Posts: 10,176
    I used foam sheets from the big box stores (thickness varies) which comes in 4' x 8' sheets. Very easy to work with, cut to size, IMO much better and cheaper than the "kits".
  • verb
    verb Posts: 10,176
    Pic from the old house:
    EndersShadow Posts: 17,740
    Any particular R value I should be looking for?
    pitdogg2 Posts: 27,537
    edited November 2018
    Well sweet cheeks how deep is your door? You can only put in there the max depth of your door....
    If you want it to work..... you do still need it to go up and down correct?
    :D
    Looks like 1.5" is what Dave used.
    One other thing the extra weight you are now putting in the door that came "uninsulated" will put more stress on the springs. Insulated doors usually come with heavier springs. That being said if a torsion spring breaks i suggest going up in spring weight a little.
    VR3 Posts: 29,626
    Double check your seal around the perimeter of the door as well as between the panels
  • verb
    verb Posts: 10,176
    Dogg is correct. R value is a function of thickness, IIRC, so you are limited as to how well insulated you can make a door. The foam sheets are all very similar in R value, so I chose the thickest one that would fit.
    :D
    1.75" deep (little more but I suck at measurements).
    VR3 wrote: »
    Yeah I already know I need to do some work there as well. Any suggestion for sealing those?
    :D
    VR3 wrote: »
    Yes go buy new seals to go around it. Cut to fit and push in better up against the door
    So something like this for filling in the door (2 layers).
    What for sealing the door? The seal's I would need would be for the sides, the bottom is fine.
  • mrbiron
    mrbiron Posts: 5,721
    Cheaper to just eat the dogs... ;)
    Dan just get the 1.5" dow/corning styrofoam friction fit it.
    They sell the stuff that goes around the door just go tell them what you need and they will show you 8 or 10 sticks cut to fit.
    Menards may be cheaper if you have one local.
    So this is what your talking about for the door right?
  • mdaudioguy
    mdaudioguy Posts: 5,164
    Are you kidding? This is the best place to ask off-the-wall questions! It's hard not to find someone here who hasn't been there/done that... :p
  • aprazer402
    aprazer402 Posts: 3,448
    I just hate when builders use non-insulated garage doors in moderate and cold climates. Another peeve is when they install 80% eff. HVAC in $500K and up new homes. But in the same house put on $30.00 cabinet/drawer pulls (just one example). Just venting. I agree, use rigid styro., I also think for an average 16' X 9' door the added weight of the insulation would not require stronger springs, these styro. boards are very light. Carry on. :)
    One 4' X 8' sheet 1.5" thick weights only 5.9 lbs. Four sheets 23.6 lbs., less 15% for gaps, hinges = 20.06 lbs. Unless you use your door 20 times a day, I think your existing springs will be fine.
    Factory made insulated doors will have more weight as they will have metal covering the insulation on the inside of the door(s). They would require stronger spring(s).
    Well this home was built in the 80 or 90s so I don’t think ANYONE was doing that then lol....
    Yes that would basically the same as verb's. Dow is blue and Owens - corning is pink.
    aprazer402 wrote: »
    Everything is cost profit ratio. While not disagreeing with you they sometimes make all sorts of shortcuts. Contractor grade is not a better grade. My pet peeve is when they use junk outlets and switches that for .30 more you get a much better outlet or switch for the most part but when you buy 100's at time it adds up so they buy out of the big dump bin.
    My point with springs is that they do break and replacing with a little heavier spring would help with the added stress on both the door and opener not having to work as hard. Yes you are correct as to how the insulated doors come. These are things i learned installing garage doors and working at a building material store for many years a lifetime ago it seems.
  • This is a good discussion. I need to do this to my double wood garage door and have been looking for ideas. The springs were replaced on my wooden door by me several years ago. What a scary dangerous job. I upgraded the springs beyond standard.
    What do you use to secure the panels to the door?
    Harry / Marietta GA
  • And what is the red thing, verb? I know it is not a dog. Maybe a lawnmower?
    Harry / Marietta GA
  • verb
    verb Posts: 10,176
    Hehe. My Snowblower! Ariens big dog. Even has heated grips!
  • verb
    verb Posts: 10,176
    In my door, each panel has a flange around the perimeter that holds the foam in place. No adhesive necessary.
    Ivan, how hard is it to replace the springs myself (remember its me), and would that be all I need to do, or would I need to make adjustments to the garage door motor or anything of that nature?
  • kevhed72
    kevhed72 Posts: 5,187
    verb wrote: »
    Nice job. Every winter for the past 15 years I said I was going to do that. Couple of questions:
    1. Did the panels stay on themselves without adhesive or tape of some type?
    2. How did you get the panel behind the braces in the middle....did they just slide through?
    3. Can you do my door? Ill buy you a six pack of your choice and throw in some old Monster speaker cable!😉
  • lightman1
    lightman1 Posts: 10,797
    Don't do it, Dan! I've seen you around tools! :s
  • oldrocker
    oldrocker Posts: 2,590
    Father in-law adjusted a garage door once, almost cut off his thumb. It was NASTY!!
    2 nephews tried to adjust my Daughters garage door that was out of adjustment.
    They tried, never got it quite right although I'm sure it can be done.
    As were attempting to fix things, I start having flashbacks of the thumb incident.
    I just called a garage company, fixed it right up....
  • ken brydson
    ken brydson Posts: 9,057
    ^^ THIS^^.
    The tension on the springs is nothing to eff around with if you don't know what your're doing...
    can't disagree with the above statements. They both need to be adjusted correctly or you can foul it up....
    Please dear god Dan DO NOT TRY TO DO IT YOURSELF!!!
    The call to a door company to do it is far cheaper than the hospital bills
  • mrbiron
    DO IT, DO IT, DO IT...
    Why adhesive? You can buy from 2-1/2" screws with buttons or washer that will hold the insulation just fine.
    Thanks guys. Don’t worry I will let the professionals handle it. Don’t need any more problems than I already got lol..
  • verb
    verb Posts: 10,176
    ^^ THIS^^.
    I agree. After installed you have to turn it a number of times to get the correct torque. I’ve seen the torque rod tool fly off because it wasn’t secured properly. Thank goodness the technician (whom I hired to do the job) wasn’t hurt.
