FXiA6 Speakers wont play below 1000 Hz
I have a pair of FXiA6 Polk Audio. Was running REW and noticed that the pair of speakers won't play below 1000 Hz, the dB is around 80 at 1000 Hz and is down below the soundstage of 60 dB around 900 Hz.
I'm assuming the mid/woofer is done. Don't know the transition from Mid/Woofer to tweeter.
Is this something that is fixable?
I checked in the bipole and dipole configuration. Then I unplugged them and plugged in a set of T15 and it played sound in the 100 Hz to 1000 Hz range. So it is something wrong with the speakers.
    VR3 Posts: 29,625
    I would say given the age, the crossover is probably no longer functioning properly
  • rooftop59
    rooftop59 Posts: 8,120
    VR3 wrote: »
    Trey those are the most recent surrounds, can’t be more than 10 years old...you really think it’s the crossover?
    Game Room 5.1.4:
    Bedroom 2.1
    pitdogg2 Posts: 27,531
    edited November 2018
    Been listening to any shows or
    playing games with gun shots and helicopters? They play nasty on stuff at volume. Don't ask how i found out.
    I'm with Dskip something sounds cooked
    VR3 Posts: 29,625
    I was thinking they were older but I'd still check the crossover first
