SRS SDA 1.2 trouble
Hey guys!
Brand new to the forum so thanks for having me! Here's the issue; I have a pair of 1.2's that was working great until I fired up the system recently (I currently use my Pioneer SX 1250...I know it's not the recommended minimum 200 WPC but I'm waiting for my Hafler DH 500 to be upgraded) and I have one speaker which is playing music but only faintly. I switched the speakers to the opposite channel and nothing changed so I know that it's not an issue with the receiver. I posed the question on another forum and the response was that it was most likely a bad capacitor in the crossover (luckily they suggested I come)...anyway, any help would be appreciated!
PS. Unfortunately my area of expertise is far afield from electrical engineering so I'm unable to fix it myself but at least I'll have a pretty good idea what to have checked. Thanks again!
    pitdogg2 Posts: 27,549
    Tweeters working?
    F1nut Posts: 52,146
    It's not a bad capacitor. Check your jumpers, if they're good it's possible the polyswitch has completely failed.
