Hybrid Monitor 7 stands
Jonesy
Does anyone have dimensions for the pedestal for this monitor stand?
http://img.photobucket.com/albums/v223/mhardy6647/earlypolkfamilyportrait.jpg
Going to build stands for some 7C's and want to imitate this design with different materials but I need the specs for the pedestal. If anyone has some, or knows the specs I'd appreciate it.
You can adjust the height if you wish.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Perfect! Thanks!
You're welcome. One of our Members @TennMan made a pair entirely out of pre-finished shelving. They came out beautiful, and required no stain or sealer. Make the right cuts, and there are no exposed/raw edges.Home Theater/2 Channel:
westmassguy wrote: »You're welcome. One of our Members @TennMan made a pair entirely out of pre-finished shelving. They came out beautiful, and required no stain or sealer. Make the right cuts, and there are no exposed/raw edges.
I believe I followed his version of the stands using the same shelving from either Home Depot or Lowes a few years ago. I just used a different color shelf than he did. They turned out great. I used them with my monitor 7s that are now gone(regrettably). Like he said, you just need to be mindful of where your cuts are so that the only unfinished edges will be towards the back of the stands.
Let me see if i can dig up a picture or two maybe.
Here is a picture of the stands @TennMan built.
Here's mine, I built mine just a little taller than his due to my listening room situation at the time.
Very Nice!Home Theater/2 Channel:
Someone on the forum named Jack also made stands like the ones I made that turned out nice. He dressed his up a little by adding the Polk badges which I thought was a nice touch.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
I like it. Nice job!Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Awesome. Thanks for the dimensions.
