My new M6 spikes...or something
Check it out - my new M6-thread speaker 'foot pads'.
Works perfectly on hardwood floors, but kind of looks like a bloke with skinny legs wearing sandals.
$10 for 8 of them, off Amazon, drop-shipped from China.
Looking grippy 👍
I've been eyeing the isolation feet by svs- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Not very spike-like, but rock them if you like them.
think they’ll work on RTi A7s?Check it out - my new M6-thread speaker 'foot pads'.
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
I'd rather do conventional spikes with the protective discs, but those can be $$
Those padded screw in feet are worthless.
What do you think about the system by svs. I have spikes but don't really want to use spikes given the weight of the Utopias at 140 pounds- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
My understanding of the SVS feet is they are meant to isolate the sub from the floor to help limit the amount of structural vibrations. Not unlike the SubDude.
From SubDude,Dramatically reduces structural vibrations through walls, floors & ceilings
My SDA's are at least 160lbs. each and they are spiked. The first thing I did with my SVS sub was add Adona Multi-Element spikes.
I think they would make a good spike substitute then plus they offer multiple bolt sizes- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Spikes couple, those decouple.
Hmm, would be curious to see if you could hear the difference- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
This is also true with components and is why racks and platforms matter so much.
Such a can of worms. Everyone seems to have different schools of thought when it comes to coupling/decoupling/isolation/anti vibration. So many different approaches and the prices easily soar into the stratosphere for some of the "high end" racks. It's all a bit overwhelming.
I had the svs feet on a sub. They did isolate it, too well. Lost a lot of that tactile feel you expect with a sub. Spiked it and sold the feet.
Damn right I can, you should know that by now. -
Spikes on speaker stands I get. But spikes on a Audio rack? Unless there’s a turntable, I don’t buy it.
That's because you are inexperienced.
I know. I forgot to add, “Can you enlighten me?” -
Spikes transfer vibration away from the item to ground.
But what vibrations come from amplifiers/pre amps/tuners etc? Is that background hum what you’re trying to fix?
And please,give me some detail. Some people may like quick easy answers, but I’m not one of them. -
Sound waves are vibrations, especially bass notes. Some folks isolate their gear from that by placing the gear in a separate room away from the speakers.
This is something I’ve wanted to do, but I don’t have another room. But what does that have to do with floor spikes on stands?
I’m not saying I wouldn’t ever buy one, or that I think it isn’t true. But I have trouble believing it, because I simply don’t understand it. The way I see it, your coupling the electronics to the floor, which the speakers are coupled to, the speakers vibrate the floor, and then that vibrates the racks... so the way I see it (probably totally wrong), spiking your racks to the floor causes more vibrations to hit your electronics. I’m probably wrong, but I’m struggling to see how this helps. Enlighten me please... -
Interesting article on the "singing capacitor". The way it is mounted to the PCB, and component chassis, may exacerbate the effect. Thus the desire to isolate (to ground) each component.
https://product.tdk.com/en/contact/faq/31_singing_capacitors_piezoelectric_effect.pdfBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Thank you. This is what I was looking for. -
No worries. I always supported the isolation idea, but today I learned about the piezoelectric effect:
Very interesting. I see the purpose of it now. Thanks!
Would be curious to compare, the Utopias enclosures varies from 1 to 3 inch thick enclosure walls, bracing and lead plates... Not much vibration leaving anything
Right now I have them in dollies so... Lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Since we’re talking SQ, any chance of your custom cable riser’s coming to fruition?
I might be innarestedAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Yeah, it'll happen just not sure when. Thanks for your interest. -
mlistens03 wrote: »Very interesting. I see the purpose of it now. Thanks!
I like your open-mindedness.Things work out best for those who make the best of the way things work out.-John Wooden -
Wrong...they are worth at least $10 drop-shipped from China.Those padded screw in feet are worthless.
Wrong again. Spikes couple themselves to speaker cabinets, but they decouple themselves from flooring, with only the smallest point of a cone touching the floor.Spikes couple, those decouple.
Coupling involves solidifying a connection between two objects, whereas decoupling minimizes the connection.
