LSiC crackle when playing pink noise
Picked up two LSi15's and a LSiC from CraigsList recently, powered by two Rotel amps I picked up earlier this year.
The center channel tweeter has a crackle. First noticed with movie audio. Tested with pink noise played through multiple amps, multiple channels, multiple connects, and multiple speaker wires. Definitely the speaker, and not the content or power system.
I don't think the tweeter is blown. I could test it in the other speakers. Fairly certain it's something in the crossover. Based on the known issues with resistors, I ordered new resistors to try first.
http://forum.polkaudio.com/discussion/162585/lsi15-tweeters-not-working#Comment_2064018
https://www.parts-express.com/mills-2-ohm-12w-non-inductive-resistor--005-2
They come in next week. Will post updates.
The LSi15s sound great. Dialed them in today.
  • mlistens03
    mlistens03 Posts: 2,767
    tn2036 wrote: »
    good luck with the repair! The LSi series is awesome, and you will enjoy them.
    Micah
    F1nut Posts: 52,008
    It's not a resistor, you have a bad tweeter.
  • mlistens03
    edited June 2018
    But he said he switched the tweeters around, and the noise stayed with the cabinet, not the tweeter. I thought the same as you when I first read the post, until I read that.
    Edit: oh you said you COULD, not you DID. In that case, it probably is the tweeters voice coil rubbing the side of the motor assembly.
    Micah
  • tn2036
    tn2036 Posts: 16
    Thank you; Any ideas for a suitable aftermarket replacement? Just called Polk and they no longer have replacements in stock.
  • mlistens03
    tn2036 wrote: »
    I know peerless makes some ring radiator tweeters available on parts express, but I don’t think they will work without crossover modifications. I also don’t know if the new LSIM tweeters will work, but it seems unlikely.
    Look on eBay and similar sites to find used replacements.
  • rooftop59
    rooftop59 Posts: 8,120
    tn2036 wrote: »
    he didn't actually test it in other speakers. Almost certainly the tweet. I know it sounds ridiculous, but if you got a really good deal I would just buy another center on ebay. Either sell the extra drivers or keep them as spares. Finding the proper replacement will be very difficult.
    Someone on the forum was selling a center really cheap. They might sell to you (some of us only sell to active members with 100+ posts, but that's entirely up to the seller).
    Game Room 5.1.4:
    Bedroom 2.1
  • K_M
    K_M Posts: 1,631
    edited June 2018
    what is the going price of the Vifa/Lsi tweeter (used) now?
    I found one damaged on Ebay for $39.99, sounds a bit steep, for a damaged item.
    The brand new Vifa XT25tg30 is only like $32.00 on parts express.....
  • rooftop59
    K_M wrote: »
    Find one and let us know ;)
    Game Room 5.1.4:
    Bedroom 2.1
  • mlistens03
    K_M wrote: »
    But that isn’t the same tweeter. The Vifa tweeters used in the LSi series was better I believe.
    Also, doesn’t the LSi15 have a different impedance tweeter than the LSiC? Or is that just the midbass drivers? If so, then you have to make sure that I feel you buy one it isn’t from a LSi15.
    VR3 Posts: 29,550
    Polk claims to alter the vifa tweeters, but they simply alter the faceplate, which can be swapped
  • K_M
    K_M Posts: 1,631
    edited June 2018
    mlistens03 wrote: »
    K_M wrote: »
    The lsiC and Lsi15 and all the lsi line use the same tweeter.
    The midbass drivers are wired in series in the Lsi15, and are slightly different in some minor ways, but if I remember correctly they were actually all 4 ohm drivers, but the impedance peak (and Qts) value was slightly different.
    In comparing both midbass drivers (we have several Lsi models) it was not apparent which was being used. So they are not all "that" different in reality.
  • mlistens03
    K_M wrote: »
    mlistens03 wrote: »
    K_M wrote: »
    Ok, good to know.
    I had a terrible dream last night where I came upstairs and the cone in both midbass drivers had fallen out and was sitting on the ground, then the dog stepped on them and crushed them. Now I know that I can use the LSi15 drivers! :wink:
  • mlistens03
    edited June 2018
    double Post...
    Post edited by mlistens03 on
  • tn2036
    tn2036 Posts: 16
    on Parts Express...
    https://www.parts-express.com/peerless-by-tymphany-xt25tg30-04-1-dual-ring-radiator-tweeter--264-1016
    Many commenters / reviews indicating they use this as a replacement for the Polk LSi series
  • mlistens03
    tn2036 wrote: »
    on Parts Express...
    A lot of people do, but I believe it is a different tweeter, which means that it will sound different. It I should possible that it’s the same, but I doubt it.
    I would just contact @dbryant about his LSiC to see if he still has one left. If so, he has them priced as a steal at around $140, and then you will have every driver except for the tweeer should they go bad in any one of your other speakers.
    Micah
