LSi25 Hum and low freq rumble
jrf
I have a pair of LSi25’s and am having the following issues with the left speaker:
1. Low level Hum, independent of input or connections.
2. Sub woofer intermittent low frequency rumble independent of input or connections.
Does Polk perform repairs or can you recommend a good service? Can I just replace the board? Please advise
Answers
The LSi25s are no longer in production, so you can’t replace the board with a new one. If you have electrical knowledge then I would suggest that you open it up and inspect the board (probably the pre amp section is the culprit). Be sure to take pics while you are in there, because some of us have electrical knowhow (I’m not the best by a long shot) and we may be able to help. -
Hello,
I would contact Polk at: 1-800-377-7655 select option 1 for assistance.
