HVLP Sprayers - Need Advice
verb
Hello my esteemed Polkies. I'm in the middle of finishing up putting wood flooring in the upstairs bedrooms, and need to refinish the painted baseboards. I filled all the nail holes and imperfections, sanded em, now I need to paint.
I don't like the stipple of a roller for them, and the paint brush always leaves a bit of brush mark. So I would like to spray em.
Any experience or recommendations? Thanks in advance!
Get the hand held Graco, I love my airless.
I read about them. What model number do you have?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I have the mid sized magnum x5 like unit from a few years ago. It's easy to use and overbuilt enough to spray my entire barn with ease.
Thin the paint a little bit and clean it up real good after done. Use yellow FROG tape and tuck regular masking tape inbetween the carpet and trim as best you can, using construction paper to mask the walls and flooring.
Test the HVLP sprayer on a piece of wood you don't care about. Once it's good to go, rock on with it. Don't put more than a 2mil paint layer on or you will introduce drips.
Any HVLP sprayer and an air compressor will do. Even the el-cheapo's. One continuous run is better than stopping and going again, as they will tend to spit when engaging and releasing.
And this dude knows paint.... I've seen his work. Immaculate. -
Russ, don't spread that kind of thing. People may get the wrong impression man.
http://audiomilitia.proboards.com/ -
So I settled on the Graco TC Pro corded version. BNIB on CL for 1/2 price! Sprayed latex primer on the baseboards. So far, so good. Works great!
I also have that model...love it for project work. I use a larger grayco for fences and other larger projects,
Oh yeah, that'll get the job done......and a few hundred more too.
Tom~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
