Pre to Amp. XLR or RCA, Which is better?
Noob here to balanced inputs. Now that I have amps and pre with XLR connections I would like to know if I can expect any noticable improvement. I am currently using a good set of "Acoustic Research Pro series directional balanced line audio cables".
Thoughts?
    Clipdat Posts: 13,100
    edited April 2018
    Generally it depends on the way that the balanced connectors are integrated, and if it is a truly balanced design.
    pitdogg2 Posts: 27,372
    agreed, just because a piece has balanced connections, doesn't make it a completely balanced circuit.
    As always, try for yourself and find out, but...I might opt for some better cables than those AR's.
    audioluvr Posts: 5,993
    How am I supposed to know if it is"truly balanced" then? Tony, if you think the cables I have need upgraded, where should I start? What's a good compromise between budget (say $100) and quality?
    Thanks all!
    Try out some inexpensive XLR cables from Monoprice and see what you think of the sound of the balanced connection. Probably the cheapest way to proceed.
    https://www.monoprice.com/product?p_id=4754
    Ok. Ordered some from Monoprice. I also have another set of RCA' s I found. No name on them but they look like good quality and appear shielded. I'll give them a try too
    Cool. Interested to hear your thoughts. I use those XLR cables to hook up my powered monitors! :)
    audioluvr wrote: »
    So I hooked up the name cables and either it's the placebo effect or the high frequencies have just been turned up a notch! Can't wait to see what new XLR's will do!
    So you go from AR to Monoprice seems a sideways move to me. I wouldn't buy monoprice anything. We use them at work and the failure rate is very high.
  • afterburnt
    afterburnt Posts: 7,892
    I dont think he went sideways, I think he got some Monoprice XLR's. If that is in fact sideways I'll be a onkeys muncle
  • voltz
    voltz Posts: 5,384
    Also Audio Advisor's has some Pangea's they just started selling
    http://www.audioadvisor.com/prodinfo.asp?number=PGIXCA
  • gmcman
    gmcman Posts: 1,864
    edited April 2018
    audioluvr wrote: »
    Thoughts?
    I used those once, until they removed an outer shield of one of my board mounted RCA terminals.
    If those have a tight grip also I would use them carefully.
    edited April 2018
    gmcman wrote: »
    audioluvr wrote: »
    Thoughts?
    That is not a problem with XLR. They lock in and use a ground pin unlike RCA
    gmcman wrote: »
    audioluvr wrote: »
    Thoughts?
    Yes they are quite tight. I twist them as I take them on and off
  • DaveHo
    DaveHo Posts: 3,583
    I use these between my Oppo 205 & Parasound P5. They are nice & won't break the bank.
    cullencable.com/copper-series-xlr/
    Nice suggestion and possible upgrade path if he likes the sound of the XLR connection with the Monoprice wires.
    DaveHo wrote: »
    DaveHo wrote: »
    Thanks Dave! That's perfect! Just under budget too!
  • gp4jesus
    gp4jesus Posts: 2,019
    edited April 2018
    tonyb wrote: »
    agreed, just because [your equipment] has balanced connections, doesn't make it a completely balanced circuit.
    this refers to your gear, not the cables
    *all connected w/Premiere ICs
  • gp4jesus
    edited April 2018
    is “them” XLR cables?
    edited April 2018
    gp4jesus wrote: »
    Monoprice interconnects in general. HDMI, RCA but no XLR stuff.
    gp4jesus wrote: »
    tonyb wrote: »
    Yes not all gear with balanced inputs/outputs is a balanced topology inside.
    How'd it go with the Monoprice XLRs?
    audioluvr wrote: »
    I could not tell the difference between the XLR's and the RCA's I have. Could just be my poor old ears have finally hit their sonic limit.
    Perhaps. Or it's possible that the way the XLR connectors are implemented on the B&K amps aren't dramatically different/better than the RCAs.
    Another possibility is that the Monoprice cables are "not good". But you didn't mention that they detracted or took anything away from the sound.
    audioluvr wrote: »
  • motorstereo
    motorstereo Posts: 2,377
    On my gear I have a choice of either xlr and rca connections. The specs show there's 4db better s/n using the xlr's. With that and a more solid connection with the xlr's I use balanced where ever I can.
    Does it make a difference in the sound? Nothing startling that jumps out at me. The biggest change I've noticed is a quieter background. It seems like a no-brainer to me to use the xlr's and I'll gladly take that 4db difference for just a simple cable swap.
  • gmcman
    gmcman Posts: 1,864
    gmcman wrote: »
    audioluvr wrote: »
    Thoughts?
    Correct, I mis-read his post and was referring to the un-balanced AR RCA's which had a death grip on the ones I used once before.
  • steveinaz
    steveinaz Posts: 19,546
    I have been very happy with how my Signal Cable analog 2 XLR's compared to my former Hero WBT RCA's. SC's = $59, Hero's = $329! I run them from my Benchmark DAC2 to my Parasound A21 amp.
  • helipilotdoug
    helipilotdoug Posts: 1,230
    If you are looking for a great bang for the buck balanced interconnect cables, please take a look at our Bravo XLR IC's with Vampire Wire XLRF and XLRM connectors. At $139 for a 3 ft. pair, I'll just about put them up against anything else out there. Of course Polkies get a 10% discount too :)
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • rburgess714
    rburgess714 Posts: 618
    Hey Doug - I received mine today and they look great and sound even better.
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
    Office
    Yamaha A-S501, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
  • helipilotdoug
    Thanks Ray. Glad to hear they arrived and you are a happy camper. :)
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
