Speaker pop noise every time I turn on my AVR
VoodooGTS
Hello,
Recently I started hearing one of my rear channel speaker (Signature S10) pop noise every time I turn on my Yamaha RX-A760. It sound like when you test for speaker polarity with a battery. Can it be a bad speaker? I made sure everything was hooked up properly. Had the S10 for about 10 months now and never had this issue before. Any advice?
Thanks.
Thanks.
That's not the speaker, that's the AVR...
Thanks for the info. I will have my Yamaha checked out.
How did all this pan out?
